Tubular K member
Yobi1Kanobi
559
Easy ? If i get a Tubular K member do I have to replace the A arms too. And what is the benifit of making the switch. I have a Canton 7 qt pan on my stroker. Will that make a difference.
Thanks
You can use the stock control arms on the QA1 kmember, but you need to grind them a little. The benfits are 1. lighter weight than stocker, 2. improved suspension geometry for better handling(depends on brand), 3. more header clearance. You won't have a problem with the 7qt pan, unless you're installing a k brace.
