Tubular K Member
I just bought a K member and while I was doing some research, I heard of people having fitment issues with the QA1 piece. The MM piece is probably the best one you can get, but it's $$$. I went with a PA Racing K member and A arms which will hopefully be here this week. I got some good reviews from people on these boards and the price was right.
I had the QA1. Mine bolted right up, no problems. Only issue I had was the car was lowered way too much after the install. I had to put 1 inch rubber isolators under the front springs. Green 94 5.0 (Roger) had the same issue. No biggie they were $10 each from Steeda. The stock A Arms will work if you grind down around the rubber housing. I used a cutting wheel ($10 at Harbor Freight) with my air compressor. Took no time.
Truthfully, it's not worth getting a Tubular K-Member if its a daily driver or a cruise car. The only thing it's good for is the headers have lots of clearance. Other than that to me it's not worth the money. Yeah it saves a little weight but it's not dramatic if your not drag racing it often.
