tune question
Dont disable the boost bypass valve. :nono: Its there for an important reason.
Are you getting the hesitation when you drive it hard and dont shift fast enough? Thats the PPRV in the tank. The thing is ghey and should be removed. What happens is if the fuel pressure hits 80+ psi it dumps the fuel into the tank. Its dumb and should be gone. You have to drop the tank and pull the sending unit. You then just cut out the little white valve where the pumps output "Y''s together and put in a regular "Y" adapter. Also a good time to replace the hoses on the assembly with better fuel hoses and also do the wiring upgrade :nice:
I need to do it on mine cause if you get above 5 grand and dont shift really really fast then it falls on its face for a half second when you shift :notnice:
i guess i'll take the steeda tubing off and see what it does, i'll call my local guy (bamachips) and see if he knows about the valve in the tune.
I haven't had any fuel related issues out of the car or hesitation, thats interesting to know that info though
