So I decided to bite the bullet and give the winter beater a tune-up... now I wish I hadn't because it won't stay running. I replaced the plugs, PCV, Air Filter, and Fuel Filter.
The old fuel filter was quite rusty and stuck in the line pretty good but I eventually got it off. Now when I fire it up it won't stay running unless I give it half-throttle or more. It doesn't seem to be misfiring when it is running which led me to believe its not getting enough fuel.
I checked to make sure I didn't put the filter in backwards, and also removed all the plugs to see if I broke any, and checked that the plug wires were seated. I installed them one by one so the wires aren't mixed up. I also put the old PCV back in to see if anything changed but it didn't. And I checked for intake leaks but found none.
Any ideas? Is it possible that the fuel line got a clog or kink in it? And if so, can I blow some air through the bleeder to try to back-flush it out of the line?
This is for a 1993 Mercury Grand Marquis BTW.
I think these cars have a return-style fuel system so if it were clogged it wouldn't rev up at all, am I correct in saying this?
