I have a question that I hope someone can answer. Why is it that Mustang tuning is such a hush hush? You can go out and buy Diablo, Superchip, Autologic, etc. plug it in and go but have no idea what is modified in the tune? You give them your list of modifications you did to your car, they program the chip, or if you can afford it, Dyno your car for a proper tune and that is it? No adjustments on the user end without expensive equipment. What if you change something later on down the road like a smaller pulley, or larger No2 jets, new injecters? Back to the Dyno, or have another chip burned/reflash.
The reason I ask is I own a V-Rod and have made many changes, ie pipes, larger throttle bodies, open intake, gearing etc. I have a Power Commander and I have been able to get tunes and or advice on tunes to make everything work perfect. The Power Commender also has to flexability to custom tune yourself? Why isn't there anything like this for our Stangs? With out costing 1000's of dollars?
