tuning??
  • Thread starter Thread starter Foxfan88
  • Start date Start date Jul 29, 2005
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jul 29, 2005
  • Jul 29, 2005
When people say "you must tune it right" or stuff like that...How do you tune efi?, or are people talking about going to a dyno and getting a chip burned??
darthcual
985
Arlington, TX
Jul 29, 2005
  • Jul 29, 2005
Yes and setting the timing is critical for your components also.
89stangalang
58
  • Jul 29, 2005
They are usually talking about getting a chip burned for when you put on a poweradder of somekind to your ride. It is of greatest importance that you know your air/fuel ratio when installing a power adder. I think that it is better to be safe than sorry with a tune.
crazypete
All my crevices are greased.
Oct 22, 2004
930
Arlington, MA
Jul 29, 2005
  • Jul 29, 2005
Or do a carb conversion and then you get to do some "traditional" tuning but with the help of the O2 sensors and an air/fuel guage.
Scorcher2005
883
South Carolina
Jul 29, 2005
  • Jul 29, 2005
usually tuning refers to setting the a/f ratio across the rpm range. Also, in addition, other things such as spark timing. It can be easily done at most dyno shops or if you want to shell out some money for a Tweecer or similar
HISSIN50
34
129
Jul 29, 2005
  • Jul 29, 2005
It is often also used for drivability reasons. After an HCI install, one's car might not idle worth a poo anymore - changing some parameters helps with that.
It can also be used to turn things on and off in the computer (emissions equipment, limiters, etc).
QDRHRSE
1,590
Palmdale, CA
Jul 29, 2005
  • Jul 29, 2005
When I talk tuning I mean the actual tune on the car. Timing, TPS setting, and fuel pressure are critical. Then you get into other stuff like plugs and wires, making sure your cap and rotor are working properly, the right stat and operating temp.....there's a lot to it. I would estimate that 8/10 guys that get chips don't need them. I think that most, not all, NA guys that get chips don't need them.
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
Digital Tuning Chip tuning in 2025, what are my options?
  • AnthonyA1234
  • Feb 3, 2025
  • 2 3
5K
Fox 5.0 Mustang Tech Jun 17, 2025
AeroCoupe
