Turbo Coupe Not Starting?
My g/f left my house the other night in the TC and the car just shut off. I pushed it back to my house and tried "popping the clutch" but couldn't get it started. The car cranks but won't fire up. I don't smell any fuel after cranking it which leaves me to believe something in the fuel system failed. I hear the fuel pump prime but can't tell if the motor is getting any fuel. Where do I start? I was thinking maybe it's the regulator so I was going to try and put a 5.0 fuel regulator on temporarily to see if that's it. If that isn't it, I guess I'll just have it towed to my local garage. I don't know much about these turbo 2.3's.
its just like a normal 2.3. If its cranking, has compression, fuel and spark, it Should run.
You can check the pressure at the fuel rail with a gauge on teh schrader vavle.
(cheap! ive seen bycicle gauges work for this !)
It could very well be the tfi...check for spark!
all else fails, check for compression :)
