turbo or supercharge?
  • Thread starter Thread starter njoliver
  • Start date Start date Jun 17, 2010
1 of 2 Next Last
N
njoliver
259
Columbus OH
Jun 17, 2010
  • Jun 17, 2010
I am wondering a question from experienced people. I am thinking of buying a turbo kit but I heard tuning them is very hard? is a supercharger easier to bolt on and tune or is it worth the while for the turbo.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Jun 17, 2010
  • Jun 17, 2010
Dude, really, if you have to ask these questions, get a GOOD H/C/I setup and call it a day, trust me if you have to worry about tuning and bolting up turbos, superchargers you're arent gonna have the know how/drive to fix the when they break, and they WILL break, no dodging that, H/C/I however, once you are done you make reliable power and dont have to **** with it everyday
Cobra912
1,777
11
39
Wish I was anywhere but here
Jun 17, 2010
  • Jun 17, 2010
I second that. Both have their issues. You're gonna need to post up a lot more info on expectations, current set-up etc.
If you do a search you will find a ton of threads based on your question.
87GT Drop Top
500
South Florida
Jun 17, 2010
  • Jun 17, 2010
That's why i just ordered a 347 from Fordstrokers. Good power and no BS.
N
njoliver
259
Columbus OH
Jun 17, 2010
  • Jun 17, 2010
I am not worried about normal maintenance, I work on cars 15 hours out of the day. I just been wondering how hard it is to tune a OBD1 car, and what is a good program to do tune with. I have a fresh 307 with F303 cam and SRP flat tops with eagle h-beam rods stock crank just had polished up, all bolted down with ARP. I am thinking of buying some AFR 70cc heads with 185cc intake and upgrading the intake. This is a ground up build this is all of have left to do to my car. I have built it for a mild road race and autocross car and still good street driving. I trying to achieve around 500hp and good amount of torque. I am planning on running around 10psi of boost.
S&B
I hate my CT. :(
1,634
695
204
Cheesehead
Jun 17, 2010
  • Jun 17, 2010
supercharger is easy and fast, and can be sold any day
LowOnFuel
24
Syracuse, NY
Jun 17, 2010
  • Jun 17, 2010
power adders
Honestly, assuming you have a stock block than I would say a supercharger is the way to go. Yes, turbo's are more efficient and can produce crazy power, but I'm assuming you have a stock block and even a well tuned s-trim can produce enough power to crack that in half. Turbo's can be very difficult to tune and can produce alot of heat, especially on a street car. Don't get me wrong, turbo's are awesome, and blowers are becoming common, but at the end of the day, do what's best for you!
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Jun 18, 2010
  • Jun 18, 2010
Blowers are becoming common? Welcome to the 90's buddy!!!
You want an answer from someone with experience, I started out with a Vortech and basically gave it away. Maybe that'll help oh and fwiw.....I daily drive my turbo car, monsoons and all.
The turbo on my car is awesome and I've drove it to cruise in's over 100 miles away to sit in traffic for literally hours at a time with zero issues.....just don't get me started on a TKO 600 that won't shift!!!lol!
millhouse
1,985
Simpsonville, SC
Jun 18, 2010
  • Jun 18, 2010
Guys, I don't know where you're getting your information from…but turbo cars are NO more difficult to tune than a N/A, supercharged or nitrous car. A tune is a tune is a tune….you're changing the spark map to retard timing while in boost and adjusting the VE table to give it more fuel when required. There is no special voo-doo magic required for a turbo car.
I also might add that simply because you have a stock block is NO reason to pick a supercharger over a turbo. Bolting a turbo on isn't automatically going to split your block in half. Hell, I've had a turbo on my ride for 5 years laying down 500rwhp without any issues with the block.
The heat issue people speak of is overblown imho. Just don't be stupid, keep everything out of the way of the turbo's and downpipes and route the plug wires appropriately. Everything else will be fine…the paint won't peel off the hood nor will the car overheat.
If I were in your shoe's, I'd pick up a nice new or used kit from B&G…get a decent custom tune and have at it. On the stock longblock with 8-10psi it should lay down close to 400rwhp with boost coming on quick and hard with a nice FAT torque curve.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Jun 18, 2010
#10
  • Jun 18, 2010
  • #10
i think He mentioned auto-x and road courses in another thread, a turbo is that last thing he should put on his car for those things, the heat thing may be overblown ( i agree for the most part) but there is heat associated with turbos, combine that with 20min continuous use, and the fact that turbos are TERRIBLE for road courses and the choice for a supercharger becomes easier
millhouse
1,985
Simpsonville, SC
Jun 18, 2010
#11
  • Jun 18, 2010
  • #11
I guess that depends on what he plans on doing at said courses. There are plenty of turbo'd vehicles that excel in those situations, things just need be setup properly. Now, the budget may be a bit higher seeing as not only will you need a more reliable turbo…but will for SURE need to upgrade the cooling system with that much continuous use. If I myself were building a car strictly for the street and road course (with no plans on dragracing), I don't think a turbo setup would be my first choice…but rather a nasty, higher revving 347 setup.
rbonella
409
@ home
Jun 18, 2010
#12
  • Jun 18, 2010
  • #12
like mentioned above, don't worry about the tuning. But a SCT 4 bank and have a good tuner dyno/tune your car whether it be sc, or turbo. I would personally do a turbo just for the sheer potential, but sc's can also make godly amounts of power. I have owned and ridden in many supercharged 5.0s and the power is linear and more manageable and a lot of fun. But the first time I rode in a turbo'd 306 and the car hit 10 psi @ 2200 rpm and blew the tires off in 4th gear, the hook was set! Turbo power can come on very quick and gnarly and be hell to control on street tires. But that can be a lot of fun too
MO, if I was going to autocross the car ALOT...supercharger
If I was going to autocross for a few weekends a year for fun...turbo
with regards to overheating and such....tackle those problems if and when they appear, no big deal
N
njoliver
259
Columbus OH
Jun 18, 2010
#13
  • Jun 18, 2010
  • #13
thanks for all of you guys for your good responses. my car is mostly going to be a street car and it will only be on road courses on occasion. I am putting on a good oil system, I been contemplating on getting a oil cooler to help out a little on suggestion for if I need one or not. I will have aluminum heads so that will help cool a little. also have aftermarket k-member to give me more room so that will help keep things cooled down. unfortunately I do have the stock block and crank, and flat top pistons so I am going to keep the boost around 8.
Like i said before it was just the tuning of the obd1 car kinda scaring me. my roommate has a turbo ls1 camaro and it was not to hard to get that running great but he has hb tuners and obd2
bentley429isBAC
922
188
84
CT
Jun 20, 2010
#14
  • Jun 20, 2010
  • #14
I started with a powerdyne went to a S trim then tried the turbo thing with a ponydown kit now I am going back to a blower after 2 years of screwing around with the turbo. A 5 speed h/c/i blower car is WAY more fun then turbo.
N
njoliver
259
Columbus OH
Jun 20, 2010
#15
  • Jun 20, 2010
  • #15
is your car efi? if so what type of tuner do you use?
bentley429isBAC
922
188
84
CT
Jun 20, 2010
#16
  • Jun 20, 2010
  • #16
Yes and stock computer with sct chip
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Jun 21, 2010
#17
  • Jun 21, 2010
  • #17
Care to explain? I'm curious.
russ1979
152
albuquerque, new mexico
Jun 21, 2010
#18
  • Jun 21, 2010
  • #18
opcorn:opcorn:opcorn:
bentley429isBAC
922
188
84
CT
Jun 21, 2010
#19
  • Jun 21, 2010
  • #19
For me the turbo was not consistant at all. Fought with some issues getting the car to desired transbrake rpm. Not a huge fan of how they make power. When it was h/c/i 5 speed and a s trim it was a lot of fun. With the turbo it wasent much faster with the 5 speed even though it was making more power/torque. When I put the auto in it was night and day even with less power making it to the tires. So turbo+auto=good if you dont mind opening a can of worms. I like the response of a blower car though. To me unless your trying to go 7's or something blowers are the way to go. SO I THINK I have not finished my new setup yet wont be sure until its complete. Plus the sound of 3.5" collectors bullets and a good size blower cant hurt
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Jun 21, 2010
#20
  • Jun 21, 2010
  • #20
Ah the rare, yet informative and helpful bentley post, take a screen shot kids it doesnt happen often
1 of 2 Next Last
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
84 turbo fan not working.
  • bdub_mkg
  • Jan 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 2, 2026
AeroCoupe
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
