Turbo swap HELP
nicklats
63
This is the second time that i have done stingers turbo swap and i still have a weak injector pulse. Can someone tell me what wires i need to connect in the removeable part of the harness. I have spark but a weak injector pulse.
I put the 88 turbo coupe throttle body on my car would that cause a weak pulse, or what other sensors would cause a weak spark. The computer and VAM were tested in another car so i know they work.
How do you ground the injector harness? In stingers swap info there was no instrustion to do so. I grounded pin 49 and the ignition ground (for the distributor) right to the battery. The connections for the case ground and the two main ground wires for the computer were cleaned and checked. The ground strap for the motor is on the firewall and on the lower intake.
When i unplug all the injectors and plug in the noid light the light is much brighter than when i have one or more injectors plugged in.
Thanks for you help!
I worked on my turbo swap into a 92 stang for 8 months then gave up and spent $500 for a painless wiring harness for the 2.3T made by Joe. I chased wiring problems and eventually gave up, retrofitting the stang harness just didn't work for me so when I hooked up joes harness the car started right up and ran perfect. If you are fed up with the wiring just bite the bullet and buy his harness. Joe's email is [email protected]
I don't know how to ground the injector harness or if its even necessary. What I meant is just make sure the contacts are good. It sounds like you already did that.
This got me thinking.....check the injector harness for continuity with a multimeter, preferably digital. Hopefully you can check each injector circuit as a whole(between the ECU pins and injectors) with an extension wire or something. Ideally you shouldn't get any resistance.
I checked each injector plug and the resistance is very low. The circuit cant take the load of one or more than one injector thats when the pulse is extremely weak to no pulse. I keep thinking its a ground problem. What about the main negative battery cable that runs to the bottom of the motor? could that be causing this?
I think that if that was the problem, you'd be getting lots of other problems too. It's a good idea to clean it anyway. I couldn't tell on my car, but if the cable connects to iron, definitely clean it anyway. If you have some, little dielectric grease might keep corrosion away longer, too.
In my second post I said that the computer grounds the injectors to make them fire. It's the other way around; the injectors are grounded and the ECU applies positive voltage to them. I guess that implies that the computer power leads need to be checked too.
If the problem isn't in any of the wiring or sensors, the only other thing that comes to mind is a failing injector driver in the ECU.
I checked the computer (by putting it in another car it ran fine)
I check the Vain Air meter
I changed the Baro sensor
I changed the TFI
I changed the Distributor
I changed the Module on the strut tower
The only other sensors i need to change are: Air Bypass, TPS, Air Charge Temp, and coolant temp. Thats all that I have left .
Hopefully one of those sensors is bad!!
Thanks for your help!
It's obvious that you are not doing something right in the wiring changes. Especially since you've had this same problem twice (meaning you've failed to do something with the wiring twice). You need to go through the wiring again one by one and verify that each one is correct. If you have any questionable wiring questions, meaning something that you aren't sure you are understanding or doing correctly, ask.
I had 2 different people help me with the swap on both occations. Can you send me a picture of you removable harness, or a more detailed description of what you did to the top harness. I think that the problem is in that top harness because I have read and re-read the instruction and so has my dad who is an engineer. The only changes that I made to that part of the harness was I repined the grey connector and i tied the 3 red/ light green wires that go to the coil packs together, and i ran a ground wire from the orange/ red wire to the battery, the rest of the plugs are untouched. (for the top part of the harness).
if the dizzy is 180 out would it cause the injector pulse to be weak, what about a "weak" coil (if there is such a thing). Bad Injector,(even though I measured the Resistance in each and they would ok).
I rechecked my engine to firewall ground strap and it was loose, I tightened it up and still the same thing. I have it attached to my lower intake bolt and then to the little green bolt on the firewall righ tnear the speedo cable. Should I get new ground straps for the car??
I changed the TPS and IAB, Coolant Temp Sensor, I put the radio noise capacitor on the red/light green wire.
Bare with me guys I know I might have repeated myself in some of these posts but I just want to get it running. Its going on 8 months that I havent drove it.
I would take it to a shop but I know they will charge me out the A** and may not even find the problem.
I would buy his harness but I have the feeling its not the harness and if I buy it and I still have the same problem then im really screwed.
For the red/grn wire i re-pined it in the grey distributor harness and then i have a wire 4 inches from the connector, spliced and ran to the coil pack(the red/grn wire is on the left side of the connector at the coil pack) On the removeable harness i cut the 3 red/grn wires that went to the 2 coil pack plugs and spliced them together. i have 12 volts at the red/ green wire. Before when I was not getting any spark I didnt have the red/grn wires spliced together.
Does that sound right Stinger?
