  • SN95 4.6L Mustang Tech
Turbo
  • Thread starter Thread starter §hadow
  • Start date Start date Oct 21, 2005
§hadow
15
CA
Oct 21, 2005
  • Oct 21, 2005
Ive come to the conclusion that there are no reasonably priced kits out thereamnit:. I was wondering if any of you have a turbo 4.6 or have done a 4.6 turbo build yourself and would like to know your experience while doing so. i would also like to know your full boost rpm and how much boost your pushing. I am on a college student budget but am willing to put in the work and make sacrifices to get my stang turbocharged. I am not stingy and am only looking for about 4 pounds or so so i can have a quick spool while developing enough power to make ls1's look like hondas (or at least be in high 12s or low 13s).
mustangman9812
661
Mars Hill, NC
Oct 21, 2005
  • Oct 21, 2005
The only kit I know of is the kit I always see in Muscle Mustangs & Fast Fords Magazine. It is like $4,000 or so. It says it produces 8lbs of Boost. I dont know much more about it I will read more into it later tonight
jasonh_86
I
May 20, 2005
1,156
Arkansas
Oct 21, 2005
  • Oct 21, 2005
MMMM turbos
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Oct 21, 2005
  • Oct 21, 2005
Keep saving.....any way you slice it, unless you're mechanically inclined enough to scrounge the wrecking yards and build your own system, it's going to set you back some. If going the turbo route is the only way for you, that's fine, but since you're obviously on a fixed income for the next few years, I'd consider Supercharging or Nitrous as a cheaper alternative. Especially if putting LS1's in your rear view mirror is your only concern.
§hadow
15
CA
Oct 21, 2005
  • Oct 21, 2005
Im pretty comfy around tools and wouldnt mind doing a turbo build from a junkyard. The problem with an S/C is that i cant find one that will cost me less then what i would think a JY turbo build would.
and one more question: is there any way i wont get reamed in california when i go to get smogged and have a turbo sitting under there ?
D
Dragstr05
643
Stafford VA
Oct 21, 2005
  • Oct 21, 2005
The kits are in most cases hideously expensive, but IMO its worth it. Some of the kits even though the run in the neighborhood of 6-7k, will come with coilovers for the front, tubular A arms and K member (im pretty sure thats what its called), plus the manifolds (for obvious reasons) and alot of other bits and pieces. I like the ability to adjust the boost at will, and basically turbo's will make more power than a supercharger in most cases (if not all) at the same boost level because turbo's have lower charge temps.
W
WillDuhhBeast
339
Jacksonville Florida
Oct 21, 2005
  • Oct 21, 2005
No parasitic drag either.
F
fellamansteve
108
Seattle
Oct 21, 2005
  • Oct 21, 2005
I know a guy who turboed his 2000 stang GT. It's a single turbo, intercooled, but I don't know any of the other specs. He blew up his plastic lower intake with it and his car is only putting down about 340 rwhp. If you want me to try to find out more about it, PM me.
Josh-'96 GT
67
  • Oct 21, 2005
There is a bunch of us on this site with a whole forum dedicated to DIY turbo builds: www.turbomustangs.com
By the way...you'll need more than 4 psi if you wanna scare the LS1 guys... . Pack 14 psi of intercooled turbo boost and then you'll be talking!
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Oct 21, 2005
#10
  • Oct 21, 2005
  • #10
Wow! There is some great info on that site. I cannot believe how many people are turbo charging their Mustangs!!!
sgarlic
3,085
Oct 21, 2005
#11
  • Oct 21, 2005
  • #11
I hope someday they fix the links for the videos on that site. They've been down about 6 months now.
GTsleeper
179
St.Louis, Missouri
Oct 21, 2005
#12
  • Oct 21, 2005
  • #12
http://modularpowerhouse.com/produc...d=121&osCsid=96881d66a2cc0597c7dfbedd47a87c72
This is probably the best deal I can find hope it helps you out.
GTsleeper
179
St.Louis, Missouri
Oct 21, 2005
#13
  • Oct 21, 2005
  • #13
This is the best deal I can find brand new hope this helps you out.
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Oct 22, 2005
#14
  • Oct 22, 2005
  • #14
whats the point of a turbo unless you're going to run more boost??
KronicRacer
502
puttering around Ft Lauderdale, FL
Oct 22, 2005
#15
  • Oct 22, 2005
  • #15
subscribing
mattkimsey
I've compiled a list to recap this thread:
Jan 22, 2004
346
Bessemer City NC
Oct 22, 2005
#16
  • Oct 22, 2005
  • #16
4psi on a stock car? lol
W
WillDuhhBeast
339
Oct 22, 2005
#17
  • Oct 22, 2005
  • #17
I think if you have money and want to spend it, go ahead and under power a turbo setup.. if you're stuck on turbos.. I don't blame you.
Fundamentally, the best Idea by far to gain 350-400 HP would be to go with a supercharger. You will save ALOT of money and I think you'll get what youre looking for out of it.
The mongoose kits at modular powerhouse seem like they will suit you well, for what you say you're looking for anyways.
But if money doesn't play a huge role.. def. go with turbo, even if you underpower it.
Thats how I see it anyways
ponysarepretty
578
#18
  • Oct 22, 2005
  • #18
High 12s is bolt on LS1 range.
hotmustang331
2,967
Bastrop,TX
Oct 23, 2005
#19
  • Oct 23, 2005
  • #19
Well, first off...dont be scared to send some boost through that plastic intake...cheister (car tuned my MPH) threw 17.5PSI through it and made 601RWHP. (built engine ofcourse) IMO just get a S/C...its cheaper and you can make plenty of power through it.
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
