  • 1994 - 1995 Specific Tech
turbo???
  • Thread starter Thread starter vladasap
  • Start date Start date Mar 4, 2008
vladasap
294
nyc, ny
Mar 4, 2008
  • Mar 4, 2008
i've been thinkin about this for a whileeeeee now
i'd love to go turbo but im not a 100% if the car will hold it
i was thinkin a single turbo no more than lets say 6-7 psi
but here's where i have my doubts - the car is a DD with over 140K on the tranny and block... maybe a little less boost would work better but im not sure if it'll hold any for long .... pleaseeee fill me in and guide me
on one hand i feel like it'll go n wont hold it but then again me and a friend installed a turbo on a 98 bmw 328i with 135K - running 10 psi - and it's been runnin real strong for the past 4 months (and the car is FASTTTT) so.... its really bugging me
im so lost and confused
millhouse
1,985
Simpsonville, SC
Mar 5, 2008
  • Mar 5, 2008
It greatly depends on the current condition of your engine. I'd suggest doing a compression and or leakdown test in order to check the condition of the rings and ring seal….as this is likely to be the first thing that will rear it's head if bad. Your best bet would to do a quick rebuild and throw some new bearings & rings back in her. Some quality head studs and gaskets (fel-pro 9333 and 8548's work great for forced induction) will go a long way as well in ensuring longevity. Or….you could run it as-is and hope for the best. There are many people that have done just that…and their rides are still running strong. 6-7psi should be enough to get you into the 450rwhp or more range with a turbo setup and your combo.
ProKiller
3,064
15
78
PA
Mar 5, 2008
  • Mar 5, 2008
i think i'd do it and just cut back on the boost a bit more. maybe like 5psi. turbo's don't need much, and you already got some good parts in there to make some power.
millhouse is right though, i'd at the very least do a compression test.
Black Stampede
1,811
Grand Rapids, MI
Mar 5, 2008
  • Mar 5, 2008
Pretty simple. If the motor checks out good just run some lower boost #s (under 10) and have fun. If it blows eventually it blows and then you can fix it when the time comes.
vladasap
294
nyc, ny
Mar 5, 2008
  • Mar 5, 2008
....it seems like im about to give it a shot =)
i spoke to a few more ppl and the responses were very much identical to that, that you guys gave me
any tips, useful pointers as what to and what not to do (what not to do might be more useful as im so into trying things out n it doesnt always turnout well
how big of a turbo should i go with???
Pokageek
2,767
MA, USA
Mar 5, 2008
  • Mar 5, 2008
There's a plus and a minus to going BIG turbo let alone stressing the oem parts (and trans) with 5 psi. You could blow it up. So be careful of the frog in slowly heated water (not frying pan) scenario..especially if it is your DD.
Advice?:
#1 "Some quality head studs and gaskets (fel-pro 9333 and 8548's work great for forced induction)"
I've HAD turbo'd car and been here and done that. Your head hasgets may already be compromised depending how long and what kinds. Go with the best and go arp as well. Too late to go arp rod bolts..just dont kill it on the revs.
#2 Want insurance on your engine ..and more power? Always Always Always INTERCOOL a turbo'd car. You don't need heat soak.
#3 MORE insurance - BEEF up your cooling - bigger rad, lower thermostat and make them fans come on like mine so it never goes past.. the "o" me thinks.
M
Mr. Hawver
32
  • Mar 5, 2008
I would head on over to The Turbo Forums (formerly Turbo Mustangs) and read, read, read, especially the stickies. Make sure to make at least your first couple posts in the "Newbie" forum, otherwise some of the regulars might decide to rip you a new one.
A single turbo that many people seem to run with great luck without breaking the bank is the Master Power 70. Some guys are getting in to the 9's with them in gutted fox bodies.
H
'86 New Turbo Build First Start/Idle Trouble. Full Tune specs attached
  • Heffay
  • Jul 10, 2022
  • Digital Self-tuning Forum
3K
Digital Self-tuning Forum Jul 12, 2022
Heffay
H
Engine Head gasket or what?
  • Foxbody1988
  • Jan 17, 2020
4K
Fox 5.0 Mustang Tech Jan 19, 2020
7991LXnSHO
T
1994 Mustang Gt Turbo/hp Help
  • tyboudreau
  • Feb 23, 2017
8K
1994 - 1995 Specific Tech Mar 4, 2017
a91what
  • Locked
Expired 1991 White Lx Turbo Coupe
  • RdRunnr
  • Aug 29, 2016
5K
Fox Body Mustangs For Sale (1979-93) Sep 29, 2016
Justin Witte
J
99 Gt Turbo Project
  • BoostStang99
  • Feb 18, 2016
3K
1996 - 2004 SN95 Mustang -General/Talk- Mar 13, 2020
alwayshi
A
