I hope your not saying that an electric supercharger is worth while. Maybe I misunderstood the joke?
I agree with your conclusion (that this device is useless), but I think it is important to clear up a few things. Bear with me, this will be tough wilthout using diagrams.
Laminar flow produces less drag... to a point. Laminar flow is more efficient when the boundary layer is small. The boundary layer is the layer of air closest to the object which the air is flowing over. In the boundary layer the velocity of the air will degrade as it gets closer to the object. The air closest to the object will have near zero velocity and the air farthest from the object will have the greatest velocity. However, the boundary layer gets thicker as it travels farther along the object. This means that after moving along an object for 6" the boundary layer is still small, but after 60" it will be larger. The boundary layer can be thought of as high turbulence. So as the boundary layer gets larger aero drag increases. After a certain distance of laminar flow, it will become beneficial to introduce some disruption of the boundary layer. I think this is the objective of this device, but the boundary layer should not grow enough to cause problems inside an engine, where the direction and velocity of the air is constantly changing as throttle and valves open and close. There have been wind tunnel tests that showed that a small hill or valley on the surface of a long part can decrease the thickness of the boundary layer and reduce drag (which will mean higher velocity is possible) One last example... Imagine a long diamter of pipe with high velocity air traveling through it. As the air travels down the pipe the boundary layer becomes thicker, reducing the diameter of the laminar flow from all sides.
Tubulent flow can actually be beneficial to airflow. A few years ago I read an SAE paper on how head designers had been increasing tubulence ( and thus pressure) in the intake port of the heads to increase airflow through the corner just above the valve and past the valve. The increase in pressure helps push the air past the restrictive parts of the intake runner. How it works deals with the angle of the floor and the roof of the runner. Not all of the details were revealed, but this would appear to be a good explanation as to why an unexperienced person can port his heads and get worse performance than in the stock condition. Actually, a supercharger and a turbo will both slow air by forcing it to change direction. In doing so though there is an increase in pressure which will help more than velocity in getting air past restrictions and into the cylinder. Increasing velocity will produce gains but not to the extent that increasing pressure will. Also keep in mind that it is TURBULENCE that gets the fuel into smaller particles. What comes out of the fuel injectors is actually rather chunky. This is why some professional head porters will not polish an intake runner (but this is still a heavily debated subject).
Just wanted to share what I have learned over the years.
There is no way I would ever buy one of these. But, if given to me I would put it on just so I could see the results for myself.
