I think some of you are brain washed with chips being bad. LOL I've had that same chip in the car since the day I bought it. I HAVE removed it, and the only difference was my rev limiter kicked in sooner. It had the surging idle just the same. I've also had the timing at 6 degrees for aprox. 4 years.
Okay, now for an update. I put everything back together last night (stock injectors and stock mass air). Still didn't hold fuel pressure, but the car started right up. It stumbled just a bit, but after a few minutes it started idling just fine. I drove it around. Not once did it act like it was going to die! It didn't seem to quite have the power it did before. But I wasn't sure what to set the fuel pressure at. It's been a while since I've had the 19lbers in. Fuel pressure was showing a steady 40psi with vaccum.
I took a trip through town. Went to Wally World. The car ran really good. Started up each time, idled everwhere I stopped.
I did my load test going down hill in 2nd gear coasting. At first it didn't surge at all.... but then it started to again. But it was different this time. It still surged, but had a hanging moment where it would build up 500 rpm and instead of bouncing back and worth, it would bounce and hang, bounce and hang. Weird, but still wasn't as bad as before.
On my test drive, I tried to get the car to die. Blurped the throttle while holding the brake and forcing it to idle back down. It did just fine. Popped the hood when I got home. My C&L pipe had popped the M/A to pipe coupler loose on the bottom. Amazingly the car ran fine. I fixed it for the drive in the morning. I went to bed last night very happy.
Fast forward to today. I get up, in a great mood. Go out jump in the car. I did NOT prime the pump like I did in the past. It took a slightly longer cranking session than I feel is normal before it fired. But it did start in the first turn of the key (barely as I was just letting up). Backed the car out of the garage. Car idled just fine. I was still happy. Took the mile and half drive to work.... car actually felt a little better. Perhaps my SOTP meter was in a good mood too.
Going down the hill, I could barely get the car to do the loaded surging... but it was there. As long as it idles and races good, I could care less. Still in a good mood.
I pulled up to my one traffic light I had to stop at on the trip to work. Sitting at the redlight... it started to stumble. Surging just a bit, but gets stronger and stronger. Car dies.
Starts right back up, but I could feel it was going to die again. I drove on to work. I sat in the turn lane at work. The car stumbled and almost died, but I gave it some gas and the rpms came back up. Pulled into the parking lot. I sat there in gear and watched the car surge 1,000 - 600 rpms, over and over. Good mood gone. I put it in park. The car jumped up to 800 rpms and idled just fine.
I plan to pull the codes when I get home.
