  • SN95 4.6L Mustang Tech
TURN OFF THE POSI
  • Thread starter Thread starter hokiesouthpaw79
  • Start date Start date May 6, 2004
hokiesouthpaw79
Chesapeake, VA
May 6, 2004
  • May 6, 2004
Does anyone know if I can get my Diablo chip burned to have it automatically turn off the posi when I start the car? It runs so much better when it's off!
Blackhawk257
Leesport,PA
May 6, 2004
  • May 6, 2004
I don't know about that but DallasMustang.com has a product that does it.
BlackenedSVT
1,841
New Jersey
May 7, 2004
  • May 7, 2004
Are you sure you even have posi-rear? As opposed to Limitted Slip Differentials...
WaltA
230
May 7, 2004
  • May 7, 2004
By either name, the differential can't be simply turned off.
However, the Traction Control can be turned off. You can do it with a special module like that from Pony Express. This module allows TC to be enabled when you start the car in order to allow the ABS/TC system to pass testing. Then, it automatically turns the TC 'off' after the testing is done.
nickthegenius
1,631
Elwood, IN
May 7, 2004
  • May 7, 2004
Yeah, and I have on of those switch-operated superchargers like the ones in Mad Max.
john_324
446
Washington, D.C.
May 7, 2004
  • May 7, 2004
"The Blower man the Blower!"
Or like the musclecar in the Mr. Clean carwash ad...
Yeah, I was thinking the same thing re the trac-lok differential...you wouldn't want to turn that off.
twogts4us
4,188
12
79
Dunedin, FL
May 7, 2004
  • May 7, 2004
To disable the standard limited slip diff - you can't.
If you have deep pockets, www.traction.eaton.com , and check out their ELocker, an electronically controlled, high perf, locking diff. (You would want to turn this off for normal street driving, to allow free wheeling of the rear tires so you could negotiate tight turns without the tires 'scrubbing' like a dump truck.)
But, I think what you really want is http://www.ponyexpressperformance.com/tractioncontrol.html , 52.95, including shipping.
The Diablo Predator, $419, (hand held tuner) is the product that can disable the Traction Control via tuning.
Personally, I do like the Traction Control when it's raining, but hate it otherwise. Hate it because I often forget to turn it off. The $52.95 option fits the bill, and is a heck of a lot cheaper, if this is all you need. Also, I'm sure there are other companies out there making a similiar product. I found this one simply by googling for "mustang traction control disable". Best of Luck!
Bullitt_#1346
767
Atlanta
May 7, 2004
  • May 7, 2004
The new Diablo chips under the "Chipmaster Revolution" brand can be set to permanently disable the Traction Control. Mine is turned off completely in this manner. I can't turn it on at all anymore.
G
GinoGT
1,862
May 8, 2004
  • May 8, 2004
Actually, I believe I read something about Mercedes putting an electromagnetic clutch on a supercharger's pulley so it wouldn't have to push the blower while crusing.
Then again, it's Mercedes and they have the patent for just about everything.
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
D
AC Circulation
  • Dtn520
  • Jun 26, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 27, 2026
LILCBRA
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
