Turn Signal Problem - WTF?!!
  • Thread starter Thread starter 65-Fstbk
  • Start date Start date Nov 27, 2008
65-Fstbk
316
26
49
Vancouver, B.C. Canada
Nov 27, 2008
  • Nov 27, 2008
65 Fastback
With headlights OFF, all the turn signals work. With headlights ON, passenger side rear doesn't work. The running light is on but the signal doesn't work. Any suggestions.
Az Pete
711
18
49
Panama City, Fl.
Nov 27, 2008
  • Nov 27, 2008
Check grounds. May not be good enough for both lights to work.
N
Nosboss
115
  • Nov 27, 2008
Do the brake lights work? I have found many problems with the rear brake/turn lights in the turn signal switch. It is behind the steering wheel and the contacts wear out.
65-Fstbk
316
26
49
Nov 27, 2008
  • Nov 27, 2008
Brake lights do work. I will check the contacts and grounds. Thx.
chepsk8
2,203
Easton, PA
Nov 29, 2008
  • Nov 29, 2008
If the grounds are OK, and the Bulbs are good - Did you check them - Turn signal switch.
But, check the bulbs first....
P
pbkelley
  • Nov 29, 2008
I had some new defective parking lights from MU that were wired wrong. Eventually burnt up the turn signal switch. Might try unplugging the front parking lights and see if the problem stops.
Once I rewired the lights - all was well. The color of the wires used is not correct.
Patrick
jst6
152
Tucson, AZ
Nov 29, 2008
  • Nov 29, 2008
i had the same issue from a missing bulb. the right side signals share a ground (common ground) and the left side share a separate ground.
as these cars are getting older minor weird stuff starts to break like the bulb pot itself may need to be replaced.
i have odd wiring issues from time to time and cannot wait to rewire the entire car with a blade fuse box.
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
68 horn and turn signals stopped working
  • connella08
  • Sep 10, 2025
Classic Mustang Specific Tech Sep 10, 2025
Fox Turn signal flasher keeps failing
  • keel
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
Electrical Turn Signal / Lights Issue
  • 86SilverFox
  • Jun 2, 2025
Fox 5.0 Mustang Tech Jun 3, 2025
General karthief
O
Resolved 2004 Mustang GT 4.6. No crank, no dash lights, No headlights or dome, No radio, no Hazards.
  • oldtimeracer
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2026
oldtimeracer
O
