turn signal tips
  • Thread starter Thread starter farmboy89
  • Start date Start date May 30, 2008
F
farmboy89
38
  • May 30, 2008
I'm gona try to fix my turn signal switch and was wondering if there are any tricks to it... its gonna be the turn signal switch and horn relay all together (66). I'm not looking forward to the steering column wiring.....
C
Cobra ssc
80
Austin, TX
May 30, 2008
  • May 30, 2008
Pray and expect to spend ALL weekend doing it!...
J/K It shouldn't be too hard, just keep track of which order everything came off. I did mine last year and it went really quick.
F
farmboy89
38
  • May 30, 2008
that sounds great. I was hoping to get it done tomorrow. its my DD so i have to do stuff around a schedule that allows me to drive it when i need to...
T
truck90278
382
Redondo Beach, CA
May 31, 2008
  • May 31, 2008
Assume your changing out the '65s turn signal switch and it is stock. It is fairly straight forward. what I have always done is on the connector at the end of the wires from the switch, cut the the wires leaving enough wire to identify the color code. I also suggest picking up a tool to remove the pins out of the connector, makes life simple. after you've run the wiring down inside the column, and out the hole it is a fairly easy matter to match up the color codes to the correct location on the connector, just do them one at a time. Also a trick I have used for fishing the new wires down the column and out the hole is to tape the new wires to a stiff piece of straing wire and use that as a guide. I use small diameter welding wire. Don't forget to intaff the protective sleeve over the wires before you hook the wires to the connector
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
68 horn and turn signals stopped working
  • connella08
  • Sep 10, 2025
Classic Mustang Specific Tech Sep 10, 2025
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
Electrical Turn Signal / Lights Issue
  • 86SilverFox
  • Jun 2, 2025
Fox 5.0 Mustang Tech Jun 3, 2025
General karthief
Z
Turn signals not working at all, but hazards do. 91 fox LX 5.0
  • Zeke1995
  • Jun 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
Jarhead67
J
