  • 2005 - 2009 Specific Tech
Turn Signal?
  • Thread starter Thread starter BennytheJet
  • Start date Start date May 26, 2006
BennytheJet
27
  • May 26, 2006
For some reason, my right turn signal started to blink a lot faster than the left. Can anyone suggest a reason why?
Thanks!
Blaven
15
  • May 27, 2006
If i remember correctly from someone else's post about this problem its a bulb thats out on whatever side the blinker is going fast on.
R
Reminisce
  • May 27, 2006
The bulb inside a blinker is about to go out whenever it starts to blink dramatically faster than usual.
F
frathouse
  • May 27, 2006
Simple answer....
If it is blinking faster, than either your front or rear bulb is out. Since the voltage is now only being passed to one bulb instead of 2, the wire in which allows the blinking heats up faster, thus making the blinking faster. So, replace your bulbs, easy fix...
BennytheJet
27
  • May 27, 2006
Thanks! I shall go replace it.
BennytheJet
27
  • May 27, 2006
So I replaced the bulb that was not working with a new one but it still didn't turn on. Any other suggestions before I take it in?
Thanks!
bleedingvayneAD
339
At my computer, duh
May 27, 2006
  • May 27, 2006
You should check your blinker fluid. This same problem happened to me last week so I popped the hood and looked at my blinker fluid container... sure enough it was bone dry. It's a simple fix that you can do yourself instead of paying the dealer kids to fill it up...
06tungstenstang
41
  • May 27, 2006
bleedingvayneAD,wow man very informative.come up with that all by yourself?
bleedingvayneAD
339
At my computer, duh
May 27, 2006
  • May 27, 2006
Yessir
F
FLY2kGT
94
Pinellas Park, FL
May 28, 2006
#10
  • May 28, 2006
  • #10
Benny...is it still blinking fast or just not turning on?
BennytheJet
27
#11
  • May 28, 2006
  • #11
Yes, they are still blinking fast, but only one of the rear lights is out,
bleedingvayneAD
339
At my computer, duh
May 28, 2006
#12
  • May 28, 2006
  • #12
Fluuuuuuuuuuuuuuuuuuuuuuuuid
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
May 28, 2006
#13
  • May 28, 2006
  • #13
one of the lights is still out? or only one light was out? you dont have LED bulbs in there do you? LED bulbs will make them flash faster unless you change the flasher also.
T
The Fang
602
Tallahassee Fl
May 28, 2006
#14
  • May 28, 2006
  • #14
Bleeding that was too funny!
BennytheJet
27
#15
  • May 28, 2006
  • #15
One light is out. The left one on the right side of the vehicle. And no do not have LED lights.
Maybe I should try some of this blinker fluid bleeding is talking about huh?!?
05gt
15
#16
  • Aug 16, 2006
  • #16
Mine just went out as well, I only have 9k miles, how can bulbs be going out already?
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
Fox Turn signal flasher keeps failing
  • keel
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
70 Mach 1 Turn Signal Indicator light issue,
  • 70 Mach
  • Oct 19, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
Mach1 Driver
M
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
