turn signal
  • Thread starter Thread starter Rusty66coupe
  • Start date Start date Sep 25, 2008
R
Rusty66coupe
38
  • Sep 25, 2008
Ok, so something strange has developed recently on the Mustang.
When I signal a right hand turn all is well.
However, when I signal for a left turn....both tail lights flash like I have the hazard lights on or something. Guess I won't be making any left hand turns with a cop behind me in the near future.
I am thinking this is either a bad turn signal switch in the steering column or something not grounded properly? The turn signal switch has been on my short list of things to replace anyway since it seems to be getting worn.
Any thoughts, suggestions or ideas?
carefact0rzero
49
columbia, sc
Sep 25, 2008
  • Sep 25, 2008
original wiring or aftermarket? i had the same problem when i rewired my car, the new harness i used was set up for separate bulbs for the turn signal and brake light, but since we use the same filament, the left turn signal would send voltage down the brake light wire and would flash both sides.
R
Rusty66coupe
38
  • Sep 25, 2008
Just replaced the rear harness and reverse lights but it is all original style wires.
carefact0rzero
49
columbia, sc
Sep 25, 2008
  • Sep 25, 2008
disconnect the column plug and find the wires that go to the rear turn signal/ brake lights. run a jumper from a hot terminal on your fuse box to the wire that is for the left light, and see if both sides come on. if so your problem is after the turn signal switch, if not, it's more than likely a bad switch.
R
Rusty66coupe
38
  • Sep 27, 2008
After looking at it some more today I tried something just grabbing at straws.
I reversed the two wires that plug into the tail light.
My guess is that the reproduction pig tail that plugs into the tail light was wired backwards.
Originally, I had the green with stripe (I think it is) plugged into the matching wire on the pig tail and the black plugged to the black and had the problem of both turn signals going when making a left turn signal.
Today, on a whim just to try...I plugged the black wire into the stripe wire and plugged the stripe wire into the black and everything works fine...
Who knew. Cheap reproductions from China really piss me off sometimes but learning quickly why NOS or original stuff gets so much more money.
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
68 headlights hot working
  • Butchd88
  • Aug 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 3, 2026
Butchd88
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
Electrical Turn Signal / Lights Issue
  • 86SilverFox
  • Jun 2, 2025
Fox 5.0 Mustang Tech Jun 3, 2025
General karthief
Z
Turn signals not working at all, but hazards do. 91 fox LX 5.0
  • Zeke1995
  • Jun 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
Jarhead67
J
