  • SN95 4.6L Mustang Tech
Turn signals not working.
  • Thread starter Thread starter mr.shovels
  • Start date Start date Jul 18, 2010
mr.shovels
  • Jul 18, 2010
I have a 03 GT that the signals stopped working on a few months ago. The emergency flashers still work. And I have checked all the fuses and replaced the turn signal modulator thing. Everything else is working except for the signals. What should be next on my list to replace or check?
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jul 18, 2010
  • Jul 18, 2010
Confirm fuse F2.18, F2.13, and F2.33 in the Central Junction Box (CJB). Suggest looking at the fuse very closely as it can be difficult to see if blown from above. Remove the fuse and check from the side one at a time.
Do both turn signals not work? Do both brake lights work? For the emergency lights, do both lights work?
Did you replace the multi-function in the steering column or the electronic flasher module? Please confim since it makes a difference in the trouble shooting.
D
dannyp8105
DEARBORN HEIGHTS, MICHIGAN
Jul 19, 2010
  • Jul 19, 2010
I HAD THE SAME THING HAPPEN TO ME PULL THE COVER OF THE STEERING COLUM AND CHECK THE WIRES THAT PLUG INTO THE SWITCH MY GROUND WIRE WAS LOOSE JUST PUSH THEM ALL BACK INTO PLACE THATS WHAT I DID AND IT WORKED. AT ONE PIONT JUST THE DRIVERSIDE SIGNALS AND BRAKE LIGHT DIDNT WORK BUT AFTER I DID THAT ALL WORKED. CAUSE THOSE TURN SIGNAL SWITCHES ARE AROUND 80$ TRY THAT AND SEE IF IT WORKS...
Fox Turn signal flasher keeps failing
  • keel
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
70 Mach 1 Turn Signal Indicator light issue,
  • 70 Mach
  • Oct 19, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
Mach1 Driver
M
