turn signals quit---PLEASE HELP
ajp91gt
9
pulled the clusterout toclean the lens and replace speedo cable...put bac together now the turn signals dont work.i dont know what happened.PCB looks ok,the arrow lights,but does not blink.im starting to hate this car!!!any help would be great.thanks
This happened to me when i was cleaning my taillights , i just got the arrow that lit up but was not blinking ,what i did was take the bulb out and put it back in and walla , id give it a wiggle .
If it was working before you took the cluster out then somthing may have not been put back right and is causing it not to work now. take the cluster back out and check the wiring, grounds, I think there is a few, fuses and switches, also helps if you have a multi/volt meter.
You are gonna have to take the instrument bezel back off and find out which wires aren't getting a connection. If you need a diagram where they go I can get you one tomorrow. This happened to me and I just played with the wires and put them in different spots in the connector till everything worked right.
