TV cable question
  • Thread starter Thread starter STROKED_LX
  • Start date Start date Jul 17, 2006
STROKED_LX
43
  • Jul 17, 2006
ive accdently lost the pin holding my TV cable to the throttle body, is there anywhere i can buy one. i tried ford dealer and searches everywhere and can not find it. my trans is a AOD
TheBocSez
652
Converse, TX
Jul 18, 2006
  • Jul 18, 2006
Are you using a brass bushing? If so and you are refering to the metal clip that holds it in place, you should be able to pick on up from any parts store or hardware store. If all else fails, 50resto sells an new bushing for 6.00
sgarlic
3,085
Jul 18, 2006
  • Jul 18, 2006
Yea just go to Ace hardware and look by their screws and stuff for a drawer with hitch pins.. they have all sorts of different sizes for like 8 cents a piece.
STROKED_LX
43
  • Jul 18, 2006
Thanks guys ill try it. i was hoping to find the orginal clip that it had but i guess ill have to go aftermarket on that part.
TheBocSez
652
Converse, TX
Jul 18, 2006
  • Jul 18, 2006
Are you using the metal bushing or the stock nylon gromett? I just bought a new nylon one from a dealership for 3.00.
F
FzyBnyFeet
Mt.Zion IL
Jul 19, 2006
  • Jul 19, 2006
Do not use the 50Resto stuff- it end up being like $12 for a washer and a cotter pin. Just go to your local tranny shop. They will give you one for about $1.00, and it works better.
STROKED_LX
43
  • Jul 20, 2006
TheBocSez it was the orginal metal clip that came on there. the Dealer told me they had no part number for it.
FzyBnyFeet ya ill probly have to make my own custom clip.
sgarlic
3,085
Jul 20, 2006
  • Jul 20, 2006
All the stock piece is is a hitch pin, just like you get at Ace.
C
Drivetrain TV cable replacement--aftermarket or search other models?
  • chazmanaz
  • Dec 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
AeroCoupe
D
AOD TV cable replacement bushing - loose pin?
  • DuluthFoxbody
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2026
DuluthFoxbody
D
AOD TV linkage
  • Titanium90
  • Jun 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2025
KRUISR
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
