  • 1994 - 1995 Specific Tech
tweecer: cold morning starts
  • Thread starter Thread starter OrangeMustangGt
  • Start date Start date Oct 9, 2007
OrangeMustangGt
1,976
Cape Cod, MA
Oct 9, 2007
  • Oct 9, 2007
my car has surged untill it stalls every morning when it gets cold outside ever since i did my h/c/i install. now that I have my tweecer i would like to fix this. It surges untill it stalls about 5 times untill its warm, then it will stay running fine..what should i do?
Stanger007
2,015
Baton Rouge, LA
Oct 10, 2007
  • Oct 10, 2007
Got a datalog and current tune we can look at?
Using CalEdit or BinaryEditor?
Go into your tables and look for "base_fuel_table_cold_enrichment_decay" or something similar. It will have numbers from around 0-5 in the table -- mostly between 0 and 1.5. Temporarily set it to all 0's to pull out added fuel at startup - see if that changes anything.
Wes
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 10, 2007
  • Oct 10, 2007
Add fuel in your cold start up menu. Not sure what its called, I use a PMS. I had the same problem and adding fuel in the cold comp menu fixed it all. Quick easy 30second fix
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 10, 2007
  • Oct 10, 2007
Thanks for your input here Mike
I see it as having two advantages for the community
1) It gives basic info on the why the workings of the PCM no longer
are able to deal with the mods
2) It gives help to those who tune with the PMS
Now having said that
I know more of you use the PMS :Word:
so
Your input in this forum would be helpful to other PMS self tuners
Grady
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
N
Need stainless carb heat shield
  • newmex999
  • Aug 29, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2026
Mcmahst
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
