tweecer issues per version
blksn955.o
3,263
st.louis mo 314
Starting a list of known bugs with the tweecer software. I would like to keep this broken down to specific versions so please if you have any comments leave the version for reference.
I run 1.3A9
The bugs I have run into are...
The spikes in the datalogs. These spikes are for example for no reason a 14v or max value will be in the middle of the data in a log.
When making any change to any tab in cal-edit the "update only" box gets checked. This needs to be un-checked before saving or writing to the eec.
feel free to add any more and issues with other versions.
+1 To all the last ones.
Plus the horrible need to Write the tweecer when you change the payloads, if you dont do this you will see out of the reallity numbers like 50 constant spark, 9000 rpms
I think also that the rounding of the numbers on all the values is also a pain
I use 1.20B3
You can't include both act and ect in a payload at the same time. If you do,
the result is both record the correct temp at the start of the dlog but it
does not change from that point on.
You can't see ect at all.
You can see act however.
When working with the maf transfer curve, you must hand load all cell values
and check after saving the file because some of the time, the values will save
to some hokey value.
I kinda think this behavior is present in some of the later versions as well
but can't be certain of this suspicion.
There is no hokey data values or data drop outs present in data logs of this software version I might add.
Grady
