Tweecker or anderson pms? an other 351w stroker questions
Xtreme Limits
375
Hudson, Florida
im building af418w , with ported protopline 215cc heads will flow madd like 225AFR's , ill have a ported victor 5.8 efi intake with 75mm TB, stud girdel roller rockers 1.6r 42lb injectors etc., i have a f303 cam i was just putting in for now an retarded it 4* so i can have max rpm at6000-6500rpm.... intill i save for twin turbos/ solid roller cam set up, with that combo witch system would be better for me im looking to make 500-560hp with my fcam tuned btw i have a \10.1:1cr when i get turbos im looking to push 6-7psi illalso have water-injection btw my cars a auto.....also do u think ill rev to 6000rpm, i have a forged crank h-beams an probe pistons, look to get 800-900hp with turbos an nos..... so if u were me what stall converter, cam, an eec tuner should i get im looking to have the revlimiter set at 6600-6800rpm do u think the f303 will get there? thanks
accel DFI you can find them on ebay.
That is the cheapest one, you can also look at FAST, Big STuff, and others. Much better to have a full stand alone and not a piggy back system.
