Digital Tuning Pms anderson
ChuckFoxLx
14
G5b1v9
Hi guys.
i want to upgrade my injector from 30 lbs to 42 lbs cause im gonna run a vortech v1 s trim
with notched piston and afr 185cc head and f303 cam + 1.6 rocker ratio.
i want to know .. i have a pms anderson .. can i setup my 42 lbs injector or i will need the maf it goes with it or i can keep my 30lbs maf a play with the pms ?
thanks im new with pms anderson
I've long since sold the PMS but may stil have the paperwork on setting up the initial values for a supercharger w/42lb injectors.
I ran basically the same set-up you have so it may be helpful to you, may take me a day to look around though.
Here you go.
This was some basic initial settings given to me by Andersen.
It was for my original 302 with Vortech V1 (8-10psi) 42lb. injectors, matching Pro M maf, Holley heads etc.
Worked pretty good for me but you'll need to do a little tweaking.
