twin turbo 383w Pinto build has started
78pinto
141
Ontario, Canada
twin turbo 383w Pinto build has started *pics added*
Hey all. I started on the mochup for the twin turbo build. Over the winter the interior is being redone, the car will be painted and a new 383 stroker dropped into the beast.
This is what my new combination will consist of
'95 roller block 351 with Eagle 383 forged internals
Z303 cam
RHS 215 aluminum heads
Edelbrock Torker II intake (needed shorter intake....don't want to put a 20 inch colw hood on it!)
CSU 750 (powdercoated red) and CSU polished bonnet
Aeromotive A1000 and 13204 regulator and 12304 filter
ponydown '79-'93 twin turbo headers...MAY need to be modifed
2 masterpower TO4E 60 trims with T4 .68 a/r undivided turbine housings
31x12x3 xs power intercooler
2 38mm Tial wastegates and Tial 50mm blow off valve
innovate wideband
AEM tru- boost controller
Built C5 with 3000 convertor (non lockup..C4 convertor and C4 bellhousing)
9 inch rear with spooled 3:50 gears (looking for 3:10's)
IT should be good for an easy 650hp on pump gas and 800 with C16 and a safe tune.
Mine's coming along very slowly.. I have pretty much all my purchasing done though. The motor is assembled up to the lower intake.. the rest of the stuff that is on is just mocked up.
I hope to have it done over winter break, I think it's realistic. I so want to do a turbo project on mine, but I'll save that for down the line still.
i'm going slow as well. Should be done for spring....but no biggie if it's not. Doing the turbo thing can be expensive.....especially if you get good quallity parts (wastegates turbos ect) If you thinking about it for the future, make sure you build your engine with all the right parts now, forged pistons lower compression and heads with thicker decks to keep the boost in the cylinders.
loaded some pics to photobucket
thanks, got the mockup done today....now to tear it all apart to weld it and finish off the rest of the car.
thanks! The hotside will be ceramic coated up to where the wastegates dump into the exhaust (including the turbine housings), the rest will be painted with ceramic high heat paint and wrapped up to the point of being under the car. Jeff
Very impressive 78pinto clean and tight looking, very trick. I have been day dreaming about doing a TT on one of my 351C engines maybe in the spring, but I have been thinking about how to do it/set it up on a C so it's "in your face" lol:D
kind of like this...
