twin turbo 383w Pinto build has started
Freaking beautiful man. How much room do you have from the radiator until you hit stuff? Also, ist here any way you could push your radiator a bit forward?
If you could stuff a Lincoln MKVIII fan behind your radiator, you'd be a happy camper for cooling.
thanks guys, i have about 1/4 of an inch from the snout to the fans. The rad is as far forward as it will go without removing the upper rad support. How thick is the mark VIII fan? I have just over 2 inches between the rad and water pump pulley/snout.
Supposedly the dimensions are.. "the dimensions of this fan are 22"W x 18.5"H x 6.25"D"
It's a real real deep fan, but you can also trim the shroud. I'd say unless you start running hot, don't sweat it. I'm modifying a lot of stuff in my car to fit it.
At 10pm tonight (July 17th) i joined the running turbo car gang! I have some small exhaust leaks, i need to set the timing, fix a small tranny cooler line leak and do a few other little odds and ends....but the damn thing runs!!!:nice: :canada:
