Two makes of MT et street drag radial tires... which is the best?
oneball
56
I have a set of 17" rims, x10.5 in the rear, and im in the market for a new set of drag radials for the spring ( my old bfg's are worn out... 315/35 r17) and i noticed there are two seperate makes of the MT's im looking at.
one, while smaller width wise, says its especially designed for quicker launches
info:
Mickey Thompson 3743R - Mickey Thompson ET Street Radial Drag Tires Details
Tire Compound: R2
Tire Overall Diameter: 26.0''
Average Roll Out/
Circumference: 82''
Tire Tread Width: 10.0''
Tire Section Width: 11.0''
Wheel Diameter: 17''
Spec Wheel Width: 9.0''
Approved Wheel Widths: 9.0-11.0''
Tire Weight: 28.0 lbs
275-Series Tire Width
672-3743R Mickey Thompson ET Street Radial Tire
P275/40R17 (26'' x 11.5'' - 17'')
R2 Compound
Special Sidewall Construction for Quicker Launches
The bigger ones are the other design, wider lower profile tires more like my old bfg's
info: Mickey Thompson 3744R - Mickey Thompson ET Street Radial Drag Tires Details
Tire Compound: R2
Tire Overall Diameter: 25.78''
Average Roll Out/
Circumference: 81''
Tire Tread Width: 11.7''
Tire Section Width: 12.7''
Spec Wheel Width: 11.0''
Approved Wheel Widths: 11.0-12.0''
Tire Weight: 31.0 lbs
315-Series Tire Width
672-3744R Mickey Thompson ET Street Radial Tire
P315/35R17 (26'' x 12.5'' - 17'')
R2 Compound
Tubeless
which would you guys choose? im trying to get the best strip performance out of my 17x10.5's... money is an issue on getting a seperate set for the track... at teh moment anyway
