typhoon intake
  • Thread starter Thread starter custom89stang
  • Start date Start date Oct 2, 2004
C
custom89stang
705
Seattle, WA
Oct 2, 2004
  • Oct 2, 2004
how much will this add...HP/Trq wise? I will have about 20HP over stock (from full exhaust) and am getting rebuilt E7TE heads....so my motor will run better, just curious about the typhoon, i have Fenderwell CAI also...thanks...how much HP over stock am i making now TOTAL? thanks guys
giddyup306
3,041
Oct 2, 2004
  • Oct 2, 2004
It'd be similar to the gains of a edelbrock intake.
C
custom89stang
705
Seattle, WA
Oct 2, 2004
  • Oct 2, 2004
well i dont know what gains the edelbrock gives ya, i know its basically a replica for cheaper....come on, i know someone has baseline dyno'd a stock 5.0 motor added an edelbrock/typhoon and dyno'd it again....10?20?30?40hp? PLUS i heard the lower intake is what is most restricting on a stock 5.0
bmo37
2,368
New Jersey
Oct 2, 2004
  • Oct 2, 2004
I can tell you when i had my basically stock motor, with 75mm maf, 70mm t-body, and cai, full exhaust, the typhoon killed my low end power, but gained on the upper rpm pulls, plus the engine reved faster.
C
custom89stang
705
Seattle, WA
Oct 2, 2004
  • Oct 2, 2004
ok thanks, that was good info, thanks bmo!
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Oct 2, 2004
  • Oct 2, 2004
Little too big for stock heads but a nice peice as mentioned in the upper RPM.
FiveLtrRiceEatr
197
Michigan
Oct 2, 2004
  • Oct 2, 2004
the intake is cheaper because it is not treated with the same care of edelbrock does, it is edelbrock, but they dont take all the "flash" out of it after it is made in the mold.
SR86
146
Alberta, canada
Oct 2, 2004
  • Oct 2, 2004
I had to clean mine up a little before putting it on, inside the runners was a lil ill....took away power from the bottom end, but seems to work well with my E-303, and 1-5/8's...
bmorrisj
449
Buena Park, CA
Oct 2, 2004
  • Oct 2, 2004
nope its a made in china piece, needs a bit of machine work to clean it up too...
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Oct 2, 2004
#10
  • Oct 2, 2004
  • #10
It's cheap and gives you room to grow, the polished version has a good look to it..I have it and it's the first thing complimented when the hood goes up. With these old cars you have to think ahead and spend wisely cause you can't sell it for what you have in it, the typhoon saves on the pocket book. I like it and at 300HP it flows lots and lots without being ported. You will like it and save some cash, but any aftermarket intake will do you well with the ported E7's.
bmo37
2,368
New Jersey
Oct 3, 2004
#11
  • Oct 3, 2004
  • #11
I agree, I bought it when it first came out for that very reason that it was cost effective, I couldn't afford to spend 500 or 600 hundred bux on an intake, when I could buy one for $275 that with a little clean up flows just the as good or better than the edelbrock rpm
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
G
S550 Headers
  • gray owl
  • Feb 1, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Feb 1, 2026
gray owl
G
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
  • Mindseye007
  • Aug 16, 2026
Mindseye007
