typoohn intake good/bad?
Same design as the edel performer RPM. If your friend has time to clean up some of the casting he can save some money by going with the P.P. intake and it will flow just as good as the edel perf. It will move the power band up... so it may or may not match what he has on the car already.
i have it on my car, yeah you really need to clean it up. it is a good deal if you got the time and tools to smooth everything out and gasket match it. with my combo the power seems to come on about 2,800-3,000 and pulls atleast to 6,500 thats where i stop the madness
I'm also running one on my car and I'm very happy with it. I wonder if I really would have benefitted much from cleaning up the casting, since mine looked pretty good out of the box. Some of these are hit or miss, but I'm also running the PP elbow and 70mm throttle body with no issues whatsoever.
the polished stuff looks nice, and the price is great, but the fitment of pro products (pp) parts with other non-pp parts is not very good.
to be specific, i have heard that the throttle body bolt holes don't line up with, for example, a tfs elbow. i hear you have to make the holes bigger to get the studs through.
and their elbow doesn't line up well with a bbk throttle body. i had a 70mm pp elbow and a 70mm bbk t/b. even though the bolt holes lined up, when i put it together and opened the throttle blade and looked at the inside edge where the throttle body and elbow bores meet, it was not even close. it was so bad that i was worried that the throttle blade would hit the edge of the elbow bore, but it didn't. so i ran with it like that :bang:, but it was annoying.
but it sounds like if you go with all pp stuff (upper, lower, elbow, and t/b), the fitment is ok ... :shrug:
Same design as the edel performer. If your friend has time to clean up some of the casting he can save some money by going with the P.P. intake and it will flow just as good as the edel perf. It will move the power band up... so it may or may not match what he has on the car already.
This is mis-information. The Typhoon intake is the same design as the Performer RPM intake. I believe the RPM range for that manifold was 1500-6500, making it great for the common 302 HCI.
The Performer's range is idle - 5500, which is great for a bolt on stock replacement.
The Typhoon is the reason that Edelbrock no longer makes the RPM, just the Performer and Performer RPM II.
In terms of quality, I've never had first hand experience. Reading off the boards though, it seems like a 50/50 split.
Adam
sorry left out the RPM part... :D
But i don't think all of what i posted was mis-information... if cleaned up it will flow as good as the real thing. and as u said above the power band is raised somewhat.
got this intake too. bought a used non polished version and polished it myself.
i also ported it too. the casting was pretty ****y. took no time to clean it up tho. i used a PP fox 70mm throttle body without a problem. when i put it all together, i didnt realize how bad the throttle body matched the intake so i have to port that when the car comes out of storage.
i wouldn't think twice about this intake if the price was right.
I have had one since they first came out, out the box uncleaned or gasket matched it made 260rwhp and 290rwtq with the following other mods: "f" cam, ported E7's, 75mm tb, 75mm MAF, 30# inj., long tubes and pro-chamber, 1.6RR.
Now with the 331 I have it still seems to be doing ok but I am about to change out a bunch of stuff and I will be removing the intake for something a little more race orientated.
Its a great budget intake if you clean it up and gasket match it. I got a lower that was already ported and whoever ported mine gasket matched it and ported it all the way through opening to opening and it is smooth like a baby bottom. I could not be happer. I have the performer upper and am in the process of getting a rpm upper so i can swap at will. but it will FORSURE need to be cleaned up/ported cause the castings are horrible!!
