  • 1994 - 1995 Specific Tech
u-joint squeak?
  • Thread starter Thread starter gumby5.0
  • Start date Start date Jul 23, 2009
G
gumby5.0
24
  • Jul 23, 2009
I am already looking at buying a FMS Aluminum Drive shaft, just want to make sure the old one is the problem. I've notice a popping/clunking noise when I accelerate in first or reverse, and now the popping is followed by a squeal that goes away around 2500rpm in first gear or by pressing the clutch pedal. Any Ideas?
toyman
1,944
54
79
Vernon BC
Jul 23, 2009
  • Jul 23, 2009
Since it goes away when the clutch is depressed I would be more inclined to think that it is the throwout bearing. If it is a U-joint the FMS aluminum D/S comes with new ones.
HISSIN50
34
129
Jul 23, 2009
  • Jul 23, 2009
I agree with Richard.
This sounds like a TOB issue.
I have had a U-joint rust inside the caps (this lead to squeaking). It happened at all speeds as I recall.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Jul 23, 2009
  • Jul 23, 2009
Yeah, that doesn't sounds like a driveshaft issue at all. I agree on the TOB.
Kurt
maximos
188
Columbus, OH
Jul 23, 2009
  • Jul 23, 2009
I don't mean to hijack the thread here...
First, I agree with everyone about the TOB.
I have a squealing sound that doesn't seem to change at all when pushing the clutch. It gets faster with the RPMs, but that's about it. It started before I had my clutch and throwout bearing replaced. It's still there despite the new parts being installed. The only thing I can really say that might be different is that most of the time when I shut off the car after a drive home from work it will sound like 2 pieces of metal slowly rubbing together for about 5-10 seconds.
I know for a fact it's coming from the clutch area, any thoughts?
G
gumby5.0
24
  • Jul 23, 2009
I just relized the squeaking is at all speed's by driving on a over pass. It's almost a grinding sound. Also I had the car on a lift and it wouldnt make the noise
MahFiVeOh
531
9
49
Ontario, Canada
Jul 23, 2009
  • Jul 23, 2009
I just replaced my u-joints recently and it was exactly as HISSIN50 described.I also have a squeaky throw out bearing that squeaks on the occasion, if you put slight pressure on the clutch pedal it goes away.In colder weather the sound is a bit different.
G
gumby5.0
24
  • Jul 23, 2009
I just took out my driveshaft and found that the front u joint had a seal ripped and it took some force to move it, but when moved it made a dry bearing type of sound, so I think i found my squeal! But we'll see if it truly was the cause of the squeal when I get a fms unit
G
gumby5.0
24
  • Jul 26, 2009
Just put the d/s in and wow! Shifts much easier and no noise!!!!!
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
Y
2004 Mustang GT AUTO (4R70W) Grinding noise when going in R or Drive does it as I put it into park too
  • yellowandblack
  • Dec 12, 2024
1996 - 2004 SN95 Mustang -General/Talk- Dec 21, 2024
89ripper
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
