UC's and LC's???????
No real gain at the dragstrip for me. BUT, the side to side movement is gone. I had planned on a pan hard bar but not now with the new control arms. Also, the rear just feels more solid not as spongy as the stock setup.
final5-0 said:
When you install one or the other or both ......
You WILL have NVH!
Just a little fyi :D
Grady
Ok Grady......:rlaugh: I got the "Will" pun.....good one......I'm lost on the NVH!........too many meetings today.....what little brain I have is fried....lol
Will .....new vehicle happiness.....:rlaugh:
:D Noise :D Vibration :D Harshness :D
I read that in a book ;)
Grady
Grady's right. I installed uppers and lowers at the same time, and I went with the spherical bushings. Talk about NOISY SONS OF GUNS! I thought my wheels were about to fall off. I've gotten used to it now.
As for the performance, the straight line traction isn't that much better, but the tail end "wiggle" is gone and it feels a lot more solid in the curves.
I have SSM lowers and stock uppers. After 1 day the stock uppers bushings at the chassis were toast. I could feel them getting worse. I am either going to get some thane' upper bushings or buy some with them since they are kinda hard to find without getting the whole 200-300$ "kit" on there own. I have a TON of wiggle from the crappy uppers.
I have Steeda uppers now, trashed the stock ones first time I went to the track. Car has been mothballed for two years now though so I will most likely replace those with newer better ones when I do the lowers. Plan on ditching the little quad shocks altogether after that.
I'm looking to add the MM uppers and lowers in a couple months. Didn't realize that they may be noisy. MM has a special bushings in the lower arms, so maybe NVH is reduced a little.
Just how bad is the overall NVH with aftermarket uppers and lowers? Are we talking rattles/noises all the time when the car is in motion OR only when driving aggressively?
My overall ride right now is much stiffer than stock, but not harsh unless the road is really really bad. I'm also sure my stock bushings on uppers/lowers must be way beyond shot.
Hey, :OT: ......did you guys do away with using radar detectors.....I saw a thread stating that but years ago I got hit with a couple in PA.......I can't see you "not" using them....
Will
