Ughhh... Battery problem...Need help.
  • Thread starter Thread starter 95GTV8
  • Start date Start date Sep 19, 2006
95GTV8
386
Washington State
Sep 19, 2006
  • Sep 19, 2006
Allright, so the other day I got a new battery, but as it turned out my starter was shot-got a new starter everything is fine. While we were putting the new battery on, to combat corosion my dad put these pads on and some vaseline on the connections. I'm driving home and the car starts shaking and the lights going on and off so i put it in neutral and turn it off and coast to a stop. I get out check all the fuses etc. After checking every fuse, I start thinking what has changed since it worked fine, ahh the battery. I go and take off those stupid pads and the car starts up fine. This was about 2 weeks ago. Today at the fred-meyer parking lot the same symptons occured, shaking & lights going on and off. I disconnected the battery terminals, and wiped out the excess vaseline, i figured that was the problem. Car starts back up drive to school great. As i'm leaving school it won't turn on. I go back and fiddle with it and scrape all the vaseline off and it's fine. Then when i'm almost home it dies again and I have to unscrew the battery terminals and have them just barely touch the battery nipples to get any power. So i'm driving up the hill with the battery cables loosely connected so my car will stay on. I am at a complete loss for what the problem is but it is wreaking havoc on my commute to school. Sorry for the god damn novel but i wanted to get all the background info out there. Thanks in advance
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Sep 19, 2006
  • Sep 19, 2006
well its obviously a connection problem. try taking a wire brush to the battery terminals and to the insides of the battery cable terminals. clean any corrosion off the terminals and make sure they are tight when you put them back on. also make sure the cables arent grounding out on anything like the hood or battery hold down or inner fender.
95GTV8
386
Washington State
Sep 19, 2006
  • Sep 19, 2006
but, why would i have no power with the terminals tightly connected, as opposed to full power with them loosely connected?
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Sep 19, 2006
  • Sep 19, 2006
maybe the insides are corroded and not making contact but when they are barely on there they are making connection from the bottom. do you have and know how to use a multi-meter or a volt meter?
95GTV8
386
Washington State
Sep 19, 2006
  • Sep 19, 2006
Ahh, the insides of the battery cables? I don't have/know how to operate a multi/volti-meter.
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Sep 19, 2006
  • Sep 19, 2006
you know what im talking about right? the inside terminal where it makes contact with the battery terminal. i was gonna say you could always test the volt drop from the battery terminal to the cable with it connected....but i wont go there
95GTV8
386
Washington State
Sep 19, 2006
  • Sep 19, 2006
Yes, I know what you mean. I will check tomorrow when it's lighter out. Thanks alot for the help.
powertrax91
598
New York
Sep 19, 2006
  • Sep 19, 2006
make sure that your battery is not making contact with the underside of the hood... just a thought
95GTV8
386
Washington State
Sep 19, 2006
  • Sep 19, 2006
Allright, I'll check that aswell. How would you go about checking that?
powertrax91
598
New York
Sep 19, 2006
#10
  • Sep 19, 2006
  • #10
you'll see a burn mark where the positive terminal is making contact with the hood
95GTV8
386
Washington State
Sep 19, 2006
#11
  • Sep 19, 2006
  • #11
O how wonderful. Thanks everybody for the help. I'll update this tomorrow.
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
