  • 1994 - 1995 Specific Tech
Uh-Oh...My Codes
  • Thread starter Thread starter Synned
  • Start date Start date Aug 5, 2005
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Aug 5, 2005
  • Aug 5, 2005
Okay this is my first time pulling codes and my first time diagnosing problems. I noticed my car felt sluggish so I Pulled codes and got this:
KOEO
33 (rc*): Insufficient EGR flow detected.
15 (o): PCM ROM test failure- failure is internal to PCM. (c) PCM KAM (Keep Alive RAM Memory) failure.
/// IM SCARED ^^
54 (orc*): ACT (Air Charge Temperature)/IAT (Intake Air Temperature) sensor voltage too high, indidcating -40degF. Suspect shorted sensor, harness.
KOER
53 (orc*): TP sensor voltage too high (indicates WOT condition). Suspect shorted TP sensor, harness.
66 (rc*): MAF (2.3 Turbo, VAF) below minimum test voltage.
32 (orc): EVP or PFE voltage below closed limit.
Guys, I have no clue what to do and need all the help I can get. I'm going to clean my MAF and IAC as a start. I don't know what else to do. Please guys...
Thanks.
CManT1914
3,172
Killeen, Texas
Aug 5, 2005
  • Aug 5, 2005
Damn dude, that's a lot of codes. Fortunately, a lot of your sensors are linked together, meaning one bad sensor can throw a few different ones out of whack.
FWIW, I had that same ACT/IAT sensor code the other day, my sensor had backed out of the inlet tube most of the way. I threaded it all the way back in, cleared the codes and it hasn't been back since.
I'd clean all your sensors, IAT, MAF, TPS. Then see what happens. As for that PCM ROM failure, I have no idea what that could be, but it doesn't sound good. Good luck bud, free bump.
HISSIN50
34
129
Aug 5, 2005
  • Aug 5, 2005
Chris, were you getting 3 digit codes when you did yours?
I had mentioned to Synned before that the two digit codes did not sound right (maybe I am wrong though. ). I thought perhaps a PIH retroversion had been done, but he is pretty sure it has not (he knows the pedigree of the car pretty well). I cant figure out why there are 2 digit codes though.
Synned
Mar 31, 2005
991
Philly
Aug 6, 2005
  • Aug 6, 2005
Hrmm, now I am realllly confused. I was almost positive that the codes were 2 digit, followed by longer gaps. Maybe I'll take a digital video of it and post as to make sure I'm not going crazy. I'll go pull them again but does anyone have any suggestions? BTW I cleaned MAF and it feels a lot better. Also, is the ACT on the throttle body?
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Aug 6, 2005
  • Aug 6, 2005
it is in the left side of the intake tube before the throttle body.
Synned
Mar 31, 2005
991
Philly
Aug 6, 2005
  • Aug 6, 2005
Thanks, I still have to figure out if/why I'm getting 2 digit codes!
CManT1914
3,172
Killeen, Texas
Aug 6, 2005
  • Aug 6, 2005
No, I get 3-digit codes. I just saw a code for the IAT that said the same thing mine did (157), and assumed it was the same one. Didn't even notice his were 2-digit, that is strange.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Aug 6, 2005
  • Aug 6, 2005
Yeah, you need to run the test again......but this time, remember that the codes are 3 digits.
First thing that happens is a strange flicker, then it will flash your engine code (half of the number of cylinders you have, i.e. 3 for v6 and 4 for V8).
Then you have to give it the test unputs. Depress the brake, turn the steering wheel, and cycle the overdrive (if auto). I think there is something else, but I can't remember.
Follow the instructions in the haynes manual and it will guide you. Also, remember that there is a .5-1 sec gap between flashes that are still the same digit, 2 second for the next digit in the code, and I think 4 for the next code.
And each code will be repeated twice, so you will see something like 114, 332, 998, 114, 332, 998.
Scott
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
J
Thanks for the information on codes 31,34,44 and 94!
  • JK86LX50
  • Mar 5, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 5, 2025
gkomo
