  • 1994 - 1995 Specific Tech
Umm.. What Is TRAC LOCK???
  • Thread starter Thread starter rude_life
  • Start date Start date Apr 1, 2005
rude_life
372
  • Apr 1, 2005
Could you guys enlighten me? Im lost.
RIO5.0
6,892
N.H.
Apr 1, 2005
  • Apr 1, 2005
Since your looking to do yours up....
Its Fords version of a posi (GM term) dif unit..
Here's the dif...you can see the clutches and shims up under the spider gears...the S spring is what puts pressure on the clutch pack...
Here is the FRPP Trak-loc rebuild kit....clutches and shims and bolt
Pinion gear with shim....puller used to remove the pinion bearing (right)
95riosnake
630
Pittsburgh, PA
Apr 1, 2005
  • Apr 1, 2005
Once again, you have pics for everything!
rude_life
372
  • Apr 2, 2005
OK..I dont mean to sound like an a$$ but dude i need the whole 9 yards..I called a shop to have them installed and they gave me a quote of $250 for labor. Im not sure of what should be rebuilt, replaced or even considered..The guy said something like he suggested bearings or something?? I am trying to get these things put in while trying not to come out of my pocket as much as possible. What are the smart things to have done while the new gears are put in so i dont have to work on it later, and which parts in there are most likely up for replacement? Thank you guys so much
N
NUTCASE
187
  • Apr 2, 2005
if you are going to do gears to then by all means go all out.
however for just doing the cluches you can stay away from alot of that extra work. first, do a burnout to make sure your t/l is actually burnt. then try just replacing the fluid with some fresh 80/90w oil and some friction modifier. sometimes that helps alot, it is always good to check the cheap fixes first. then, if it is still nessesary to do the cluches, do a thread search !!!NO WAIT I FORGOT DATABASE IS GONE!!!! just post up and someone will assist you furthur with replacement
RIO5.0
6,892
N.H.
Apr 2, 2005
  • Apr 2, 2005
Read away...Search for write-up's to get the skinny...This ones good...
http://www.corral.net/tech/drivetrain/gears.html
Airaid reduction sleeve?
  • BriansNSane
  • Dec 20, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 20, 2025
BriansNSane
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
L
Box of old Ford locks
  • Lockguy1967
  • Nov 9, 2025
  • What is it Worth?!?!?
What is it Worth?!?!? Nov 9, 2025
Lockguy1967
L
