Its Fords version of a posi (GM term) dif unit..
Here's the dif...you can see the clutches and shims up under the spider gears...the S spring is what puts pressure on the clutch pack...
Here is the FRPP Trak-loc rebuild kit....clutches and shims and bolt
Pinion gear with shim....puller used to remove the pinion bearing (right)
