Interior and Upholstery Unable to switch A/C controls
May 8, 2005
So, after the previous fight with getting the car running, she's operating absolutely wonderful. HOWEVER....
Now I cannot change the settings for the climate control. I know normally if there's bad vacuum, it defaults to the defrost. That's just the thing. I replaced all the vacuum lines because I thought that was the problem, but it is also blowing out of the floor vents too. The only thing I can seem to control is the blower speed. Right now I don't appear to have heat either, but have yet to take a look at the heater core to identify that problem. It's still in the upper 80s here so AC is still a concern. There does not seem to be any positive detent on the mode selector switch, so I'm not entirely sure it's good (and finding a replacement seems impossible). Any one have any advice on some other things I should check?
Vacuum, Vacuum and more Vacuum. There are several vacuum servos that open and close the various doors that control airflow. Check the vacuum feed from the engine first and then check for vacuum at the vacuum servo when they are selected on the HVAC control panel.
The following are diagrams courtesy of Tmoss & Stang&2birds
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring; http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
TFI module wiring for 94-95 Mustang GT
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-IgnitionControlModule.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mustangs
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
Complete computer, actuator & sensor wiring diagram for 88-90 Mass Air Mustangs
5.0 wiring diagram for Fuel Injectors, Sensors, and Actuators
Ignition switch wiring
O2 sensor wiring harness
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
Mustang 5.0 Lights and Radio schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/mustangFoxLights-Radio_diag.gif
87-92 power window wiring
93 power window wiring
T5 Cutaway showing T5 internal parts
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
Convertible top motor wiring http://www.veryuseful.com/mustang/tech/engine/images/mustang88VertTopMotorCkt.gif
Engine mounted fuel injector harness
Location of the TPS, IAB, and the 10-pin connectors on a 5.0, picture by TMoss:
Starter circuit
Alternator diagram for 94-95 Mustangs.
