K. So I'm at 11.65 V and it doesn't change much with the engine running. When the Regulator is by-passed with a running engine I get 14 V...hmmmmm. Seems to say that the alt is working ok.
I thought "ok, replace the regulator" right??? Wrong
I could really use some help on the wiring. This will probably show how much I don't know about this circuit. Here's my take on it.
F= FLD(whatever that means?) = ground.
S=Stat (Alternator- right - but then why do I have only two wires, one to the ignition module and the other to the fuse panel - is this wrong?)
A=?? Power wire. There is also a black wire to what could be some kind of capacitor. What the heck is going on here?
Does anyone else get a higher voltage when by-passing(maybe 14 to 16V)? If so I wonder if it could be an alternator issue still?
