Underdash Light 66 Mustang
  • Thread starter Thread starter AEinPA
  • Start date Start date Aug 2, 2005
AEinPA
  • Aug 2, 2005
Not coming on, regardless of which door is open.
I am pretty much a novice, guys.
New bulbs (BP 67, though when I pulled them - two different bulbs were in place, "67" and "97" - no owners manual). Gotta think wiring/fuse. I'm a product of more modern cars (first and oldest I owned was a 76 Mustang II), so I'm a little out of sorts.
Here's the problem.
I don't know much about the electrical system. Actually, that's being boastful. I know almost nothing regarding wiring.
Buddy told me it might be a matter of the wire not being grounded.
Anyone want to walk the dummy through this?
65and68Stang
148
Raleigh, NC
Aug 2, 2005
  • Aug 2, 2005
Those underdash lights have to have a very good ground to work...there is a screw that holds the metal light housing to the underside of the dash. I'd unscrew that so the housing comes free and scuff up the area of the dash that contacts the housing when its installed with some sandpaper.
Also check that all the fuses are good (not sure which one it is on a 65/66). The only other thing I could thnk of that would be an easy fix would be the door plunger has gone bad.
Good luck!
Kelton
iskwezm
4,159
20
79
Rowland Heights,California
Aug 2, 2005
  • Aug 2, 2005
get a test light and ground the clip end.Put the sharp end in the ceter of the bulb receptacle and check for power,no power,probably blown fuse.Simple enough?
MustangMatt1966
1,004
Orlando Fl.
Aug 3, 2005
  • Aug 3, 2005
also, what happend to me, when the door opens, there is a little thing that springs up to turn the lights on and off when you clost the door, mine broke off and my lights wouldnt work period, might want to check that, just a thought
iskwezm
4,159
20
79
Aug 3, 2005
  • Aug 3, 2005
unless both door switches are broken(he said it doenst matter which door),i dont think thats it.
MustangMatt1966
1,004
Orlando Fl.
Aug 3, 2005
  • Aug 3, 2005
ahh, didnt think about that, my bad
65mistress
405
Generica USA
Aug 3, 2005
  • Aug 3, 2005
Ok, not to be hijacker, but they have LED lights for everything else, do they make them for the under dash interior lights too, does anyone know?
66Runt
680
Aug 3, 2005
  • Aug 3, 2005
Loose fuse holder
is what I found on my '66. Over the years I guess they just kind of got loose. Cleaned up the fuse and spring clips that hold the fuse then squeezed them so the fuse would be a tight fit and everything worked well.
Good luck,
Scott
jb1dsl
566
Marianna, Fl.
Aug 3, 2005
  • Aug 3, 2005
are the rear interior lights on a fastback on the same fuse ase the under dash lights, I have rear lights but no under dash. I used to could bump them and they would work but not anymore
65mistress
405
Generica USA
Aug 3, 2005
#10
  • Aug 3, 2005
  • #10
Ok, silly question, have you checked the connectors under the dash? With time and moisture it's possible that they may have gunk built up in there not allowing for a good connection.
brtnstrns
606
11
Lewisville, TX
Aug 3, 2005
#11
  • Aug 3, 2005
  • #11
my passenger side underdash light doesnt come on all the time...sometimes if i punch the metal part of the dash it will make it turn on...anyone know what the deal with that is?
AEinPA
#12
  • Aug 3, 2005
  • #12
Well, I haven't been able to get serious time under the dash. Flippin hot in PA. I'm thinking it might have more to do with the light housing. Would use the test light...if I can find one. Should be able to, though.
The springs work with the door buttons, for what it's worth.
iskwezm
4,159
20
79
Aug 3, 2005
#13
  • Aug 3, 2005
  • #13
yes they do and they also have hyper whites
iskwezm
4,159
20
79
Aug 3, 2005
#14
  • Aug 3, 2005
  • #14
yes,same fuse,you probably have bad connections or 2 bad bulbs
iskwezm
4,159
20
79
Aug 3, 2005
#15
  • Aug 3, 2005
  • #15
it probably has a bad ground or connection
65up2d8
281
Memphis, TN
Aug 4, 2005
#16
  • Aug 4, 2005
  • #16
Who are they?
iskwezm
4,159
20
79
Aug 4, 2005
#17
  • Aug 4, 2005
  • #17
65up2d8 said:
Who are they?
Ill get the brand and part number from my catalog
65mistress
405
Generica USA
Aug 5, 2005
#18
  • Aug 5, 2005
  • #18
Isk- Any luck finding those bulbs?
AE - did you find the tester?
iskwezm
4,159
20
79
Aug 6, 2005
#19
  • Aug 6, 2005
  • #19
Sorry man, spent 12 hours yesterday helping the G/f buy a car,DAMN SCION tc,she changed her mind from a 05 V6 Mustang
oh,whats the bulb number,i took mine out
D
Double check my electrical diagnosis of light issues on 65 Coupe
  • Duke City Novice
  • Jan 21, 2024
1965 - 1973 Classic Mustangs -General/Talk- Feb 4, 2024
AeroCoupe
9
1995 Mustang GT Crank no Start
  • 95gtV
  • Sep 1, 2023
  • 1994 - 1995 Specific Tech
3K
1994 - 1995 Specific Tech Dec 4, 2023
SRago
V
1966 Mustang GT - Courtesy/Interior Light issue
  • Veneratio
  • Jun 11, 2022
2K
1965 - 1973 Classic Mustangs -General/Talk- Jun 15, 2022
COramprat
A
'66 Mustang alternator wiring quesiton
  • Andy Saleen
  • Feb 5, 2022
2K
Classic Mustang Specific Tech Feb 10, 2022
Andy Saleen
A
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
