Steeda. 8 years. No issues. More noticeable than TB plenum combo. Better mpg too.
Pulleys pay for themselves in gas. For me they are a no-brainer mod if you are going to stay NA.Worth a tenth at the track too.
Could I change out all the pulleys except for the crank? I want the crank to be the same as stock when I put a blower on the car.
8 years and no problems is pretty evident. thanks for the info. still considering doing a tb/plenum if i can snag one cheap off ebay and add a set of pulleys as well. also throw in a cheap cai kit. would love a jlt but sheesh, the price.
how bad are the steeda's to install? not too bad?
I paid 50 bucks to get my pulleys installed. You need a tool that I didnt have.
BTW. Mr Raburn has a K&N cold air kit on clearance that you might want to consider. K&N Cold Air Kit 96-04 4.6 57-2519-3 $150. See the thread at the top of the tech forum.
Rent the tool at Autozone. Its very easy to put them on.
Im getting rid of my UD pulleys. They cause problems if you DD car with everyday things on. Like GPS Charger+Radar detector+Radio. Soon as you hit a red light your idle drops down real low and the battery doesn't charge correctly.
Matter of fact i just hand bucket washed my car with the car running so i could keep warm in 20 degrees weasther. Accidentally left the heater blower on with the motor off for about 5 minutes.
Tried to start the car and the battery was dead @ the car wash.![]()
its either gonna be steeda or march brand. both have the sfi balancers. cheapest i can find new is $190 shipped on the steeda pulleys.
The fact the car running @ idle for 15 minute while hand washing the car with the under drive pulleys pulled the battery down pretty low. Then once i turned off the car but left the blower running on a already low battery killed it. If i wouldve had regular pulleys the battery would be charging while sitting @ idle.. unlike the UD pulley where it charges while driving only.
LOL. They cause more problems than good for SOME people.
trust me.. i know this was a user error, still Reg. pulleys wouldn't had this problem
