underdrive pulleys
  • Thread starter Thread starter lx_coupe
  • Start date Start date Jul 18, 2004
lx_coupe
missouri
Jul 18, 2004
  • Jul 18, 2004
I have a quick question concerning underdrive pulleys. Is it worth the extra cost to purchase aluminum pulleys instead of steel? Im not concerned about what the pulleys look like.
shallto
464
OBX, NC
Jul 18, 2004
  • Jul 18, 2004
Save your money and don't buy either. The gain is not worth the it. Save up for a good torque conveertor.
91notch5.0
623
warren mi
Jul 18, 2004
  • Jul 18, 2004
pullies are defenitly a good mod. i have steel pullies and noticed a gain
85GTlover
704
  • Jul 18, 2004
It would be all looks the weight difference can't be that signifigent, and considering what they are would not be a factor. The aluminums would not rust, and look better longer. The cheapest would be good enough.....I think. I have read many times that they do make a difference and many people say that. I have read up to 15hp but that is likely on a hopped up engine not a stock one. The downside is if you do not have a 3G alt, and have AC, power options, big amp etc it may cause problems at idle for sure. You can leave the alt pulley stock to help this, but that is taking away some of the advantage of the other pullies. If your car does not have a lot of these options......get them!!!!! My car came with smaller pullies so I cannot compare and I have no power options so I have no problems with the alt, plus I hand polished my alt, so I ain't buying another one.
super302
I'd do anything for free Bapples
May 29, 2004
2,878
Davenport, IA
Jul 18, 2004
  • Jul 18, 2004
pulleys are good, don't waste your money on alluminum tho.
shallto
464
OBX, NC
Jul 18, 2004
  • Jul 18, 2004
I noticed a difference also, but soon after I added the pullies I noticed the temp would rise a little quicker than normal. I added a four row radiator and electric fan. I then started waking up to dead batteries , so I added the powermaster alt which turned out to be junk so I added the PA performane alt. So these 80 dollar pullies ended up costing me around 500 dollars. So now your talking 15 HP max for 600 dollars
Like I said ,,not worth it.
drgn5.0
603
  • Jul 18, 2004
don't use the alt underdrive and all will be good.
ALMOST STOCK
1,250
41
88
CA.
Jul 18, 2004
  • Jul 18, 2004
I bought the March power and amp pulley kit and I've have had no problem at all with over heating even while the AC is on in stop and go traffic or with a charging of the battery. I still have my stock Radiator and Alt also.
As far a gains the motor seems to rev a little quicker is about all I can tell, but I sure didn't feel a 15 hp increase.
Was it worth it
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jul 18, 2004
  • Jul 18, 2004
Rotational weight is a major issue, weather enought to justify cost, I don't know. Underdrives are one of the best bang for the buck mods you can do. They really help out in the low gears when your engine is revving up fast.
1990LXDropTop
430
Western Massachusetts
Jul 18, 2004
#10
  • Jul 18, 2004
  • #10
I have the FMS steel pulleys and hardly noticed a difference with them. The car reved a little easier, but I didn't notice a hp gain. Its hard to feel 5-7hp IMO.
91notch5.0
623
warren mi
Jul 18, 2004
#11
  • Jul 18, 2004
  • #11
all of the little things add up. i have had zero problems and i went from 14.7 to 14.4 with pullies and ram air.
the stock pullies are for extreme conditions-the coldest and hottest of weather.
i put the ram air on first and did not feel a thing. i felt the pullies. i agree with the post about just not using the alt pully if you are worried.
EddieHaskell
Banned
Jul 18, 2004
73
North Carolina
Jul 18, 2004
#12
  • Jul 18, 2004
  • #12
I think the aluminum ones are about 8 lbs lighter.
C
crazy_canuck999
137
Victoria, BC, Canada
Jul 18, 2004
#13
  • Jul 18, 2004
  • #13
if you've done the 3g alt upgrade, can you use the alternator pulley from the March set, or will it not fit?
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jul 18, 2004
#14
  • Jul 18, 2004
  • #14
where can you get a stock alternator pulley? im tryin to find one so i can swap out my underdrive pulley for it. actually wouldnt mind swapping them all out
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Jul 18, 2004
#15
  • Jul 18, 2004
  • #15
I've been thinkin of this too for awhile, but I was reluctant cuz of my stereo... but that is true that you can leave tha alt pulley tha same... I might have to buy some now, haha
MadMatt5oh
441
St Paul, MN
Jul 18, 2004
#16
  • Jul 18, 2004
  • #16
My alt is a 95 Mustanggg 130 amp. It actually has a much larger pulley than my overdrives do
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jul 18, 2004
#17
  • Jul 18, 2004
  • #17
another question...ive never really had a chance to check the size difference between underdrives and stock pullies. are the underdrives bigger or smaller? i sound like such a newb right now
90mustangGT
2,773
17
89
Dallas, GA
Jul 18, 2004
#18
  • Jul 18, 2004
  • #18
ASP and March sells individual pullies. I think ASP is better priced. I know ASP sells an alternator overdrive pulley, and both sell different choices in pulley configurations. Some configurations your hardly underdriven at all like some of the power and amp series's, all you really did is swap out steel for alumimum, but some kits are extreme like the race pullies.
I run the 2.5" alt pulley, there is a 3.5" unit also. I also have a 3" race crank pulley that is supposed to be here tomorow, but I don't if it will work for regular usage, but every little bit helps, at least for the track.
Engine Underdrive pulleys
  • Mindseye007
  • Feb 1, 2026
Fox 5.0 Mustang Tech Feb 14, 2026
Willybill32
T
Engine Removal of Steeda Underdrive pulley
  • THughes
  • Jun 30, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 4, 2026
Dino Dino Bambino
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
H
Aluminum timing chain guides ?
  • healy1963
  • May 5, 2026
2005 - 2014 S-197 Mustang -General/Talk- May 5, 2026
healy1963
H
Fog horn sound
  • brandon4v
  • Jun 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 23, 2026
squeak93
