Underdrive Pulleys
sandman0023
116
Chicago
I have a set of Ford Racing Underdrive pulleys in my 89GT, 120 Powermaster alt & an Optima battery. I also just replaced the starter (for the second time in a year). My other mods are in my sig. The car sounds weak when I start it and while its running and the belt moves slow. I heard the problem is the pulleys and if I put the stock ones back on it will run better. Is this the only way to fix this issue?
i've heard alot of the higher amp alts have the same size pulley as an UD set would have. doesnt really matter though, i had charging issues with my UD pulleys so i changed back to stock alt pulley and its fine now.
Alternators only produce about 10% of their total output at idle. This is why your car "sounds weak"
The simple solution is to get an overdriven pulley for the alternator. This will spin the alternator up faster and sooner so your electrical system isn't relying on the battery as much.
so does that mean he needs to put the stock pully on?
it all depends on what pulley is currently on the Crank / Water Pump and alternator. In my case I ran the BBK steel underdriven pulley kit. It came with a smaller crank pulley, water pump pulley and Alternator pulley. When I put them on, i instantly noticed a huge drop in voltage. Even with a 3G alternator I still didn't have the voltage I wanted (with the U/D pulley kit on) until I switched to the overdriven alternator pulley.
You also had a very good point about the tensioner. When I swapped out my pulley set, I my belt tension was out of spec and I needed a shorter belt to correct it.
The underdrive pullies sure do catch a lot of grief here. I ran mine for 4 years with underdrives. Sure, it would only show about 11 volts at idle but fortunately for me I rarely drive around at an idle. 4 years with a Sears Diehard battery and never once did I have to get a jump start or have to charge the battery.
