What are the devices and plugs located on the passenger side between the firewall and the strut mount near the fender? They are bolted into the sheetmetal and I don't know what it is and would love to rip it out! Also, I have removed the cruise control from behind the driver's fender. What is behind the passenger's fender that can come out? I noticed some vaccuum lines going in there but I think they are for my charcoal canister and from what I understand, that should stay. Thanks!
intake. I am having the intake matched to the TB and the rest ported out this weekend. It also has TF TW heads, Crane cam, etc etc. It runs great! However, there is a solenoid under my hot air induction filter that looks plugged into the canister, but there are no vaccuum lines attached to the two ports on it (T). I don't know what that is. Another thing I don't know what it is is the big goldish solenoid sticking off the TB area of the intake manifold pointing sort of backwards. Is this my EGR valve? It has a vac line going from it to a little 5 line connector coming from the fender/firewall area (didn't look that hard). That connector also has a line coming from the intake manifold to it as well. The other 3 or so ports are capped. What does that thing go to? If I remove all of this crap, will a tune be able to turn the CEL off? Thanks.
