Universal joints
  • Thread starter Thread starter MahFiVeOh
  • Start date Start date Mar 12, 2009
MahFiVeOh
531
9
49
Ontario, Canada
Mar 12, 2009
  • Mar 12, 2009
Are they all the same or are they different? The reason i ask is because the local Carquest said there are 3 different kinds. One for aluminum, steel and one for steel with aluminum coupling (pretty sure thats what he said) drive shafts. Are they just giving me the run around or what? I'd like to replace them this w/e if possible because i dont need one letting go doing 110 kms down the highway to work.
Thx
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Mar 12, 2009
  • Mar 12, 2009
The aluminum driveshaft might have a differently-sized U-joint, and if you're adapting the yoke from one of those onto a steel shaft (or a steel shaft's yoke onto an alum. shaft), then there would be one with two different ends. Otherwise, if you know for sure your driveshaft is the stock one, just get the one listed for the steel shaft and you'll be fine.
MahFiVeOh
531
9
49
Ontario, Canada
Mar 12, 2009
  • Mar 12, 2009
As far as i know its stock, i guess ill look under and check it out tomorrow.
Thx for the quick reply.
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Mar 12, 2009
  • Mar 12, 2009
buy ford parts
HISSIN50
34
129
Mar 13, 2009
  • Mar 13, 2009
And I'd try for a non-greaseable U-joint. They're stronger.
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
L
SN95 Interior / Exterior Color Combinations - were some not possible?
  • lparsons42
  • Aug 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 2, 2025
Mustang5L5
