  • SVT Tech Forum
Unplugged vacuum line?
  • Thread starter Thread starter missouri_guy197
  • Start date Start date Sep 23, 2005
missouri_guy197
1,441
St. Louis, MO
Sep 23, 2005
  • Sep 23, 2005
Would having the 2 vacuum lines going to the EGR vacuum regulator unplugged cause the car to not perform as well? I noticed that mine weren't connected today and I'm wondering if it being like that would have been affecting my times at the track
Like would it cause the computer to pull timing or something like that?
cold96snake
20+ Year Stangneter
Jan 26, 2004
817
Truly, out to sea
Sep 25, 2005
  • Sep 25, 2005
I would say no. The EGR V/R is related to the emissions back-up system. It's only used when the engine reaches a certain heat level, then it turns on. Under full throttle, it's not an issue. At idle maybe, but the most you should expect is a CE light. Stupid emissions control.
missouri_guy197
1,441
St. Louis, MO
Sep 25, 2005
  • Sep 25, 2005
Actually I found out that with it unplugged the EGR wasn't recirculating exhaust gases properly producing more NOx and making a lean condition...which inturn could cause detonation that the knock sensors would detect and cause timing to be pulled...
cold96snake
20+ Year Stangneter
Jan 26, 2004
817
Truly, out to sea
Sep 25, 2005
  • Sep 25, 2005
.... under stock ecu.
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
  • SVT Tech Forum
