Unworking tach -
  • Thread starter Thread starter Car RamRod
  • Start date Start date Apr 22, 2005
Car RamRod
Banned
Mar 30, 2005
623
Queens, NYC
Apr 22, 2005
  • Apr 22, 2005
I bought a 4cyl conversion car. The tach works, but the speedo doesnt (140mph). What do I need to check first when trying to fix it?
thanks.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Apr 22, 2005
  • Apr 22, 2005
Grounds
Car RamRod
Banned
Mar 30, 2005
623
Queens, NYC
Apr 22, 2005
  • Apr 22, 2005
do you know where the grounds usually are? btw If I g2 pull apart the dash Im not gonna fix it now.
jb89coupe
416
CT
Apr 22, 2005
  • Apr 22, 2005
The speedo is mechanical.. check to make sure the speedo cable is hooked up to the tranny and to the back of the gauge, you'll have to pull the cluster out to do that.
jb89coupe
416
CT
Apr 22, 2005
  • Apr 22, 2005
You have to remove the panel below the steering wheel, the plastic surrounding the steering column, and the cluster shroud to get to it. It's like 10 screws, doesn't take long at all. You'll need a small torx bit and a phillips screwdriver.
Car RamRod
Banned
Mar 30, 2005
623
Queens, NYC
Apr 22, 2005
  • Apr 22, 2005
rockin. Ill takle that tomorow. Where on the tranny does it plug in (t5)?
And if thats all hooked up, is there anything else I should check while Ive got the cluster out?
thankss
jb89coupe
416
CT
Apr 22, 2005
  • Apr 22, 2005
thankss
If you jack your car up you can follow the speedo cable from under the hood to the tranny, it's up towards the front on the driver's side. The only reasons your speedo won't physically move are A) cable is disconnected from one end, B) cable is bad or the drive/driven gear is stripped, or C) the speedo itself is broken (pretty unlikely).. My personal guess would be whoever swapped the cluster when they did the conversion didn't snap the cable on the back of the speedo correctly and it fell off.
Car RamRod
Banned
Mar 30, 2005
623
Queens, NYC
Apr 30, 2005
  • Apr 30, 2005
well I found the problem, the jackass that had the car before me had the speedo cable sittin on the exhaust. Melted through. Im workin on getting a parts car, otherwise I guess Ill buy one.
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
Grounding issue?
  • 86SilverFox
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 31, 2026
86SilverFox
D
Progress Thread Calypso Green 92 LX Hatchback
  • Dakar09
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
rednotch
P
Electrical 1988 GT Wrong Cluster- causing electrical issues?
  • pindude80
  • May 6, 2025
Fox 5.0 Mustang Tech May 6, 2025
pindude80
P
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
