- Apr 9, 2003
- 559
- 0
- 16
347 stroker on the way. Part list for the build is as follows.
9 to 1 compression KB forged piston
I beam rods
hellfire plasma rings
Main cap Girdle
Windage tray
HV oil pump
7 qt pan
28 oz balnce Flywheel and SFI dampner.
Trick Flow R intake
Trick Flow Heads
Hi-6 crane ingnition
Summit Distributor
65mm TB
DIABLO Chip custom tune
POWERDYNE 9#
3.73 gear
aluminum drive shaft
subframe connectors
upper and lower control arms
Tokico shocks and Springs
TKO 600
custom clutch
Just got the parts below
ARP head studs
42 # inj
80mm OBD II maf with adapter harness
Comp cam 533/544 lift
new valve springs
Fel-pro gasket kit /one piece oilpan gasket
T-rex booster pump
Holley 255 force induction pump
Here are the questions?
I need to get the Heads checked for spring binding with this cam according to Summit what are your experience with doing this.Is it worth the trouble to run this cam or should I just go back to my Trick Flow Stg 1. I am using this cam through personal recomendations from guys with sim setups and comp cams and the 114 LSA as apposed to the TF's 112 LSA.
second I have a set of aluminum fuel rails to install I need A standalone FPR but are they worth the install with the stock fuel lines.
third is my cooling system on our cars what where is the best place to get a two row aluminum rad...steeda is out of the question $$$$$$ seen some after market stuff on ebay. what do you think about these pieces.Or should i spring the few extra bucks for a fluidyne.
Last should I sell my NOS kit or run it over my blower. Kinda like an insurance incase I'm about to get
I have a bad feeling about running 2 power adders I was thinking of setting it up about a 25 shot to cool the air intake. Kinda like Meth inj..Just a thought.Plus I kinda like the purge Kit.
I appreciate you help guys
Any other suggestion are welcomed. Or Gaps in my set-up.
I beam rods
Main cap Girdle
Windage tray
HV oil pump
7 qt pan
Trick Flow R intake
Trick Flow Heads
Summit Distributor
65mm TB
POWERDYNE 9#
3.73 gear
subframe connectors
TKO 600
custom clutch
ARP head studs
42 # inj
new valve springs
T-rex booster pump
