  • 1994 - 1995 Specific Tech
Update:sqweeking Noise
  • Thread starter Thread starter Dustins_95GT
  • Start date Start date Jun 26, 2004
1 of 2 Next Last
D
Dustins_95GT
  • Jun 26, 2004
A few weeks ago I posted about a sqweeking noise coming from what I thought was the motor. Everyone that reply'd said it had to do with the belt(which is what I thought). Well I replaced the belt and the idler pully and nothing has changed..still sqweeks. Then I found something very interesting and very important that I missed. After a year of this noise getting louder and driving me nuts, I never noticed that as soon as I touch the clutch....it stops. Bad clutch? Can someone help me out on this? If it is my clutch getting bad then I guess a new(upgraded) clutch is a good way to start the modification frenzy(cars still bone stock). Any thoughts?
9
95cobra50
167
  • Jun 26, 2004
my friends 96 gt was sqweeking and it turned out to be part of his suspension that was worn out
HISSIN50
34
129
Jun 26, 2004
  • Jun 26, 2004
if lightly pressing the clutch quells the noise, i would bet it is your TOB. that is the only thing you are changing when pressing the pedal (and is quite common).
good luck.
D
Dustins_95GT
  • Jun 26, 2004
Just lightly touching the clutch makes it stop. How hard/expensive Is this to fix? Thanks for your input.
N
Na5.0HO
342
Michigan
Jun 26, 2004
  • Jun 26, 2004
I have the same problem... sounds like the TOB (Throwout bearing). I believe you can grease this with an outlet available on the trans but I am not positive... never done it before??? It's replaceable as well... good luck
Jason
D
Dustins_95GT
  • Jun 26, 2004
nvm, just saw a post a few posts down about it. SHould be fairly easy. thanks guys.
HoofnIt
1,175
North Carolina
Jun 26, 2004
  • Jun 26, 2004
You cannot access the throwout bearing without at least separating the the tranny from the bellhousing. It has no grease zerk and I doubt adding grease would help. The throwout bearing is not that expensive and while you're there you might as well take the tranny all the way out and change the clutch.
95GTeee
181
Western CT
Jun 26, 2004
  • Jun 26, 2004
Something else to consider (or another possibility) is that the noise is coming from the distributor. Mine squeeks like a bad throw-out bearing, but after using the long screwdriver stethoscope trick - I found it to be a bad bearing in the distrib! I replaced my idler pulley too. Maybe pressing on the clutch slightly changes the RPMs just enough to make a difference in the distrib. Make sure the noise is coming from UNDER you car if you think it's a bad TOB.
Just a thought from someone who chased the squeeks for several weeks!
JJ95GTID
1,141
Phoenix, AZ
Jun 26, 2004
  • Jun 26, 2004
My TOB acted the same way. So in went the King Cobra clutch kit which includes the TOB, pressure plate and clutch disk. You don't need the bolt/dowel kit that is suggested if you use your original flywheel. Mine was in good shape so I left it. It is easy to do. Just take your time. When reinstalling the tranny you will notice that the last inch won't go in. Hook up the clutch cable and have someone depress the clutch peddle and slide her in that last inch. This will prevent pushing out the pilot bearing in the flywheel. BTW a tranny jack is awesome in this situation. Best price I found was on www.buyfordracing.com
VIPERn94Five-0
3,352
Poughkeepsie, NY
Jun 26, 2004
#10
  • Jun 26, 2004
  • #10
yeah, TOB sounds right to me...mine does the same thing....
Anthony
D
Dustins_95GT
#11
  • Jun 26, 2004
  • #11
Ive been wanting to get an upgraded clutch anyway. This gives me a pretty good reason. I found a brand new King Cobra set for 130$ on ebay..is this a good deal?
HISSIN50
34
129
Jun 26, 2004
#12
  • Jun 26, 2004
  • #12
Na5.0, what i think you mean is that you can get some grease onto the retainer (what the TOB slides on). the aluminum ones can get chewed up and sometimes some grease will temporariliy ease the operation.
i would add that upgrading the retainer to steel while in there would probably be a good idea....
as for the KC clutch: the oem units are Valeo's - a very reputable brand, IMHO.
i think the KC units are also Valeo. someone had a thread about this a few days ago,and they said something about the packaging being different or something on some ebay guy's KC. i might pay a few bucks for something from another (non auction) vendor. think of the pennies or percentage of pennies a clutch costs, per shift. i say all of this, only if you have doubts about the ebay unit (like the other thread's poster did)....if not, GFI....good luck.
95GTvert[bv12]
1,792
Lake Tahoe, NV
Jun 26, 2004
#13
  • Jun 26, 2004
  • #13
Get a spec stage 2 or 3 you'll never regret it
HISSIN50
34
129
Jun 26, 2004
#14
  • Jun 26, 2004
  • #14
im hoping you can educate me. i always thought that with clutches, more was not always better. if he has a stock ride, what is the advantage of a stage 2 or 3 over a stage 1? the stage one is good for quite a bit of torque...
(im not trying to be a smarty pants, but the logic behind using a stage 2 or 3 in a stock application is a little foreign to stupid ol' me).
VIPERn94Five-0
3,352
Poughkeepsie, NY
Jun 26, 2004
#15
  • Jun 26, 2004
  • #15
well obviously the advantage is going to be the Stage 2 and 3 will hold future power upgrades better than the Stage 1...BUT you you bring up a good point about too much clutch...now im not huge into drag racing(which is apparent since my car has never been to the track) but IMO the clutch should be the weak link in your setup....especially with our hit or miss brittle T5 trannys....id rather have the slightly weaker clutch instead of blowing apart T5's....now if you have the cash to go to a Viper Spec T56 or something of that sort than thats different...but on a T5...a clutch that gets overpowered may save your tranny from a premature death...
Anthony
9
94Red5.0
41
#16
  • Jun 27, 2004
  • #16
I have the same problem with the squeek and when u put the clutch in it disappears and was also told it was the TOB (so irritating). How much is this going to run to replace with and without labor and could I replace it myself or should I take it in to a tranny shop?
HISSIN50
34
129
Jun 27, 2004
#17
  • Jun 27, 2004
  • #17
well, it really depends upon your mechanical inclination, experience and comfort level. i think the best thing to do is to read the repair manual. you will see a write up and pics of what you have to do. often times, once someone has done something, their response is that job XXX is so easy, but it was probably a little daunting on the first attempt (like most things).
but reading up or asking a bud who knows you is probably the best idea (that i know of). or get a friend and a 6 pack (or keg, depending upon your friend) and do it. best of both worlds - you learn and have a safety net.
that said, it is an academic job - unbolting and bolting.
Anthony, thanks for the info. im not real conversant with Spec's specs (specifications), but with other clutches, one runs into real streetability issues with too steep a stage of clutch. i would not want a chatterbox for in town...(dont Specs use the same PP for the first two or three stages - just a different disk?).
i did just want to toss out that too much clutch is not always a good thing - if someone wanted to do such, i would suggest they find a friend or friend of a friend with a similar set up to what they want to run, and drive it.
i do agree with ya about the weak link aspect. that coupled with the possibility of streetability issues would be two strikes against it, in my book.
if a bunch of upgrades are done later, a clutch, trans, and or scattershield would probably come along anyhow.
where is Jordan - he would laugh. he posted a thread about which clutch to do, and we beat it to death like this for 2 or 3 pages.
just my two cents worth of thinking. and Anthony, please dont take this as me being a jerk who just disagrees. sometimes i play advocate for a different opinion to find out what is best (in this case, it is my opinion). i really thought you could go overboard with the clutch itself (not worring about the weak-link aspect), otherwise why offer stage one (or two) - we would all run stage 3's.
like i said, your view point is a new one on me - i welcome being educated. but since i am not comfortable with your idea, im kinda beating it to death. i really want to know if i should try a stage 2 or three next time, which is why im floggin the horse. please take no offense. Anthony.
VIPERn94Five-0
3,352
Poughkeepsie, NY
Jun 27, 2004
#18
  • Jun 27, 2004
  • #18
none taken....the Stage 3 is a chatterbox i believe, at least till its broken in...i doubt it will cause any problems honestly, except for maybe some streetability(nothing major i would think)....my point was just something to think on when choosing a clutch....our weak T5's dont need any added stress ya know? lol...ive seen plenty of guys break em on street tires with OEM clutches lol....
...its also ther same kinda thing with a headgasket in a sense....say in a nicew boosted application, your gonna want a nice quality headgasket, but id rather the headgasket be the weak link as far as the motor goes...i know its some work for head gasket replacements, but id rather blow out a HG then crack something else...maybe "weak link" is the wrong way to look at it....maybe safeguard would be better....id feel better about things if i knew the clutch was gonna slip before the tranny blows, or the HG is gonna go before i crack a head lol....
Anthony
HISSIN50
34
129
Jun 27, 2004
#19
  • Jun 27, 2004
  • #19
Anthony
i agree in full. we be cool. i get what you are saying (kind of a controlled chaos idea - when something goes, you engineered what it will be).
makes sense to me.
and thanks for the clutch info. i really was asking sincerely. i would opt for a stage 2 or 3 if there were no downsides (compared to a stage one, on a mostly stock motor)....hence my having asked. thanks again, Anthony.
VIPERn94Five-0
3,352
Poughkeepsie, NY
Jun 27, 2004
#20
  • Jun 27, 2004
  • #20
makes sense to me.
no problem....id wait on a final decision until a couple more chime in...there are others who have more personal experience with the different stages than i do...
Anthony
1 of 2 Next Last
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
90Gt squeal/chirp when hot
  • Bvoss59
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2025
General karthief
