Upgrading Alternator Questions
Hey guys,
I am looking to getting an electric fan set up and found one for a decent price and comes with 12” fan, thermostat fan control and all mounting hardware. I am almost positive I will have to buy an electric thermostat, but the set up is only $162.
I know I need to upgrade my alternator. Anyone know what amp is ok and where to get a decent one for a decent price? Can you overpower the car? I know some cars you will burn the wiring harness if you power it too much, didn't know if that would be the same case here. I don't run a stereo system, except for an amp with component speakers.
If anyone could help me out with this, so I can start putting the funds away, I would appreciate it!
By the way, anyone notice any power difference with doing this mod? I think I am going to do the pulley upgrade with it as well.
Thanks
Husker
Perhaps RedFoxGT can steer you in the right direction?
Oh, that's right. Well, you can start with a 130A 3G Alternator kit from PA Performance. Be sure to upgrade your ground wires to the same gauge as your power wire.
Yes, you will see a tremendous difference in the way the electronics in your car act. Your dash lights and gauges will be much brighter, won't dim when you put a load on them, and will overall be much better. The stock charging system is barely adequate, even by the standards of the year these cars were built.
Also, try not to undo all of your money and hard work by underdriving or overdriving the alternator to the point where you negate the benefits of having it in the first place. Pulley size is important. Assuming that you're smarter than multi-million dollar R&D tech departments is usually a recipe for disaster.
Stangnet 3G install sticky http://www.stangnet.com/mustang-forums/646825-3g-alternator-install-how.html#post6673702
Alternator wiring
attachment.php
Starter solenoid wiring 86-91 model cars
Connect the fused 4 gauge wire to the alternator and the battery side of the starter solenoid.
attachment.php
Starter solenoid wiring 92-93 Model cars.
attachment.php
For a 135 amp circuit breaker, see http://www.wiringproducts.com/index1.html price is $34.05
For a 120 amp circuit breaker see http://www.delcity.net/delcity/servlet/catalog?parentid=193073&page=1 price is $29.45
Fuse holder from local NAPA dealer - Item#: BK 7821143 Price: $10.49
Product Features: Thermal Plastic Holder For AMG Type Fuse Rated From 100 To 300 amp
See WWW.partsexpress.com for the fuse & fuse holder.
Fuse @ $3.90 each (need one) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=071-952
Fuse holder @ $5.80 each (need one). http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=263-630
Check on the wire prices, they tend to change often. Copper is an expensive commodity these days.
4 gauge black wire @ about $1.95 a foot (use string to lay out routing & determine length). http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-196
4 gauge red wire @ about $1.95 a foot (use string to lay out routing & determine length). http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-194
4 gauge ring crimp terminals (package of 5) $3.25. http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=095-584
3/4 “ Black heat shrink tubing, 4ft length, $3.56
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=082-058
3/4 “ Red heat shrink tubing, 4ft length, $3.56
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=082-064
Pre-fab 4 gauge cables with lugs already on the ends are available in most auto parts stores. Look for the starter switch to starter cables.
Under no circumstances connect the two 10 gauge black/white wires to the 3G alternator. If the fuse blows in the 4 gauge wire, the two 10 gauge wires will be overloaded to the point of catching fire and burning up the wiring harness.
The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges. Any car that has a 3G alternator needs a 4 gauge ground wire running from the block to the chassis ground where the battery pigtail ground connects.
LarsD, they said the fan control will operate up to two electric fans. The fan control unit is only $53. I can always buy a dual racing fan on Ebay. I have heard from many people they are successful.
The 3G Alternator doesn't need any modification to the bracket does it?
The mounting bracket needs some grinding at the lower rear corner for proper clearance. See
http://www.mustangcentral.net/tech/alternator.html - excellent pictures of installation
Oh OK, I was under the impression you were going to try and use one 12" fan.
I did the 3G upgrade for under $40. I got a 130 amp 3G off a Taurus, clocked it for my Mustang, and picked up the 4 gauge power wire and negative plus the inline fuse. I do keep a higher voltage at idle vs. the old stock one, but for some reason when I hit a power button such as for the windows my voltage still drops very low causing my lights to go extremely dark. I haven't figured out why that is. It just seems like the power windows are drawing a ton of voltage.
Make a trip to the local auto parts chain store (AutoZone, Advanced Auto Parts, etc.) and have the alternator tested in the car. It's free, and can spot problems that would go undetected otherwise.
