upgrading to 9 psi?
  • Thread starter Thread starter SBC RACING
  • Start date Start date Aug 8, 2004
SBC RACING
141
Santa Barbara, Califonia
Aug 8, 2004
  • Aug 8, 2004
Anyone upgrade their powerdyne blower to 9 psi, What do i need to do this?
T
TheUser
1,859
Springfield, MO
Aug 8, 2004
  • Aug 8, 2004
Basically all you have to do is change from a 6 psi pulley to a 9 psi pulley, which probably also require a different belt i'd assume. Do you currently have a bypass valve? I don't think you HAVE to have a bypass for 6 lbs, but you do need one for 9 lbs.
TT91
1,536
Paramus, NJ
Aug 8, 2004
  • Aug 8, 2004
The standard bosch bypass valve that Vorech and all the other companies sell with there basic kits is enough for anything under 10psi. If your upgrading to a 9psi pulley, you wont be seeing 9psi as often as you think, unless you drive around at WOT all the time.
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
Supercharger and What else do I need? 1990 Saleen Vert 5spd
  • AlbertaGolfer68
  • Aug 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
General karthief
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
